Tait TP9900 - Bluetooth and Encryption features
human8472
The TP9900 Multi-Band and Multi-Mode portable specs mention Bluetooth support. Does anyone know what that Bluetooth support entails?
Does the TP9900 support a Bluetooth speaker mic?
Does the TP9900 support programming via Bluetooth?
As far as encryption ...
Does the TP9900 require a license purchase/key for use of digital encryption?
Does the TP9900 require a keyloader for encryption use?
Yes.
Don't know.
Yes, via feature license, I believe. Price will vary depending on what algorithm you need.
For P25 use, AES, DES or ARC4, it requires a keyloader or OTAR.
For DMR, AES, DES or ARC4, it'll allow the programming software to load keys, but check with your agency first. Any reputable public safety agency won't give out keys and will require them to be loaded by them using the keyloader or OTAR.
There may be someone else that has better info on this. I've got some info since we were looking at the 9800/9900. Things may have changed since then.
