Talk Permit Tone XTS 5000R
DEProgner
Ohio
I have an XTS 5000R, I have looked through the other threads about the talk permit tone, but only found people wanting to change it to the "3 beeps". I have MDC1200 programmed, and I want to GET RID of the talk permit tone all together. Is this possible? Trying to clear a building is hard enough without stupid tones emitting from my radio. Sorry, I should add the radio is used in conventional, so the tone is a steady tone.
FFPM571
Nashvillle
Since you have a permit tone I assume your on a trunked system. If you are and you want to change something in the radios set up it would require changes in the radio with the CPS. If its on a trunked system the only person who should make any changes to the program is the system admin or one of their techs.
RKG
Boston, MA
Most likely the steady tone you are referring to is an MDC "sidetone." This is emitted to prevent you from talking over the PTT-ID while your radio is sending it, which (if done) results in clipping your initial words. You have two choices:
A) Disable the PTT-ID.
B) Disable the sidetone, and be disciplined enough to pause for a second or two after pressing the PTT and before beginning to speak.
Both of these functions are controlled from the Conventional-MDC System screen for the MDC system associated with the "conventional personality" for the channel in question. Un-checking "Leading PTT-ID" will disable sending the MDC PTT-ID for all channels using this MDC System. Unchecking "PTT-ID Sidetone" (leaving "Leading PTT-ID" checked) will preserve the sending of the PTT-ID but disable the sidetone.
You could use the "PTT ID Short Sidetone"
All you would hear is a short beep not the long steady tone.
rescue161
KE4FHH
Hubert, NC
Or you can set PTT ID to Post.
I was going to say the same thing, but some departments do not allow Post ID as a user can turn their radio off before they unkey and never be identified. There was a person doing that at one of my former jobs. They'd key up, cause all sorts of interference and then turn the radio off before they unkeyed. They got caught, but it was just a hassle, so the powers that be changed all radios to Pre-ID. Never had a problem after that.
RKG
Boston, MA
Many of my clients use Pre- ID on repeated channels and Post- ID on direct. This gives both the user and the listener an audible clue if direct has been selected.
62Truck
Ordinary Subscriber
Uranus
I understand. When I used to work for a Comm Shop we had a client who had their employees messing on the radio as well so they bought new radios that allowed MDC and programmed for MDC and cut down on the horse playing.
