Talkabout 7100 enquiry
Darth_vader
So I recently came into possession of a set of three lightly used Moto Talkabout T-7100 combo rigs. (Don't ask how.) There was no documentation with them, although I'm already more or less intimately familiar with configuring them from my years of working with the crappy model-5000 Talkabouts, since they're more or less configured the same way.
Thing is, how do you shut off that annoying end-of-transmission beep dysfeature on a 7100? It seems I can sit there holding down "+" and switching the unit on and off until the cows come home and it doesn't seem to make any difference!
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
This is the very first link that came up when I googled talk about t7100 manual:
http://www.buytwowayradios.com/Products/Motorola/manuals/T7100-manual.pdf
(I bet you would have found it, too, if you had googled it.)
Darth_vader
Thanks.
Hmmm... page 17 says to push and hold "+" whilst switching the unit on. Strange. So either I must have a bad set of rigs or the information in the manual is wrong. The procedure to disable the annoying key tones seems to work, though.
"I'll bet you would have found it, too, had you run a World Wide Web search for it."
No, I probably wouldn't have, since neither Startpage nor Ixquick turned up anything of the sort. (I think they were having problems on Sunday, since I wasn't getting much response out of either site when looking for other things, either.) Look at my sigblock--that's a hint.
That, and being a proper name Google is a noun, not a verb. Proper names are not used as verbs in English.
