This is all one hell of a headache
If your EZ-Scan database (on your PC) is up to date, simply do a Library Import to add the system.
Set the Type as Preferred
On the next screen, choose your state, and select the option for Counties & Cities
Select "Next" in the lower right portion of the screen
Choose your county on the next screen, & select Trunked Systems as your data type
Once you've done that, again press Next in the lower right corner.
That gets you to a screen showing trunked systems in that county.
I've selected the Erway system. In the lower right, again, click the Sites. Just make sure that all of them, or at least the one you want, is selected.
In the lower right is a selection for Talkgroups. Select that to make sure that the ones you want are selected,
Once you've verified that you have the sites & talkgroups you want selected, click on "Import Selected Channels"
That takes you to a screen where you can designate which scanlist you want these attached to. Select the scanlist, then click Import Channels to add the system to your programming file.
