- Joined
- Nov 16, 2004
- Messages
- 2,049
Incident: 0377 Type: Truck Fire Location: SR20 JWO MITCHELL FLATS Zoom Map: 7874 6C <javascript:void(0)> info as of: 3/25/2008 10:30:06 AM
ADDITIONAL DETAILS
10:22AM CAL T, HAS TRAFFIC CONTROL AT SR20 & WALNUT
10:21AM 52 COPY LINE 36 & WILL CHECK WITH 39-S1 WHEN HE GOES 97
10:21AM SET OF DBL TANKERS HAULING 75,000 GAL OF KEROSENE, WILL LET IT BURN OUT, SOME SPOT FIRES / WILL BE EXTENDED CLOSURE
10:19AM CLEAR LAKE UNIT IS A HWY 16 AND 20 CAL TRANS ALREADY THERE UNIT IS NOT NEEDED DO WE NEED ANY ADDITIONAL UNITS AT THE SCENE
10:19AM 39-S1 ASSUMING THE I/C SR20 JWO MITCHELL FLATS
10:19AM SANDERS BIG TOW 1023 FOR INFO
10:16AM 1039 DOT - LINE 31
10:16AM N860 ENRT SB 5 FROM NORMAN
10:13AM 51, SR20 1 MILE JWO MITCHELL FLATS / IC / CT IS ALSO 97 // TK & TRLR / HAULING AVIATION FUEL
10:12AM RTD TO UNITS MDC S
10:12AM 7-12 ENRT ETA APPX 10, PER UKIAH LOG 119
10:11AM UKIAH DISP REQ ING CT TO PUT SOMETHING ON THE CMS IN LAKE CO / STILL NO ETA FOR THE LAKE CO UNIT
10:10AM THEY HAVE NO SIGN BOARDS;;;THEY ARE ALREADY BEING USED
10:09AM SAC, INFO FOR YOUR SR16 (WDL UNITS)
10:08AM CAL T, PER 39-S1 REQ THE SIGN BOARD AT SR20 & E ST (WILLIAMS AREA)
10:07AM ROUTED ENTAC
10:06AM 39-S1 COPY LINE 20
10:06AM WHAT 1020 DO YOU WANT SIGN BOARD AT, CT IS AT WALNUT NOW BLOCKING BOTH DIRECTIONS
10:06AM TWO CLEAR LAKE UNITS ENRT ONE FROM WALKER RIDGE PER UKA
10:05AM APPEAL DEMOCRAT ENRT W/CREDENTIALS ENRT/ PRESS ALLOWED TO COME TO AREA / PER 39-S1
10:03AM FIRE 97, WEST END OF MITCHELL FLATS
10:03AM TMC, LINE 14 / CAN U ALSO RESP A UNIT & POSS SIGN BOARD
10:03AM SEE IF WILLIAMS PD CAN UNTIL CAL T IS 97
10:01AM WILLIAMS PD TO CLOSE SR20 AT E ST, ADV TRAFFIC TO STAY OO THE AREA
9:59AM 1039 UKIAH WILL RECONTACT WITH UNIT S ETA
9:58AM ^** UPDATE SIG ALERT ** TRAFFIC WILL BE DIVERTED ONTO SOUTH BOUND STATE ROUTE 16
9:56AM 39-S1 ENRT FROM OFC
9:56AM ROUTED TO UKIAH, LINE 10
9:55AM REQ CLEAR LAKE UNIT TO WEST SIDE TO DIVERT SB ON SR16
9:55AM EXTREMELY HEAVY SMOKE
9:55AM CT SUPERVISOR ENRT
9:55AM ^** SIG ALERT ** STATE ROUTE 20 EAST OR HWY 16, THE BOAD IS COMPLETELY BLOCKED BY A BIG RIG THAT IS ON FIRE, NO ESTIMATED TIME OF OPENING
9:54AM CAL TRANS KNOWS
9:54AM TMC, CONFIRM YOU HAVE THIS INFO
9:53AM 51 ENRT FROM GRIMES, 52 ENRT FROM MAX AREA
9:50AM RWY BLKED
9:50AM BIG RIG TANKER ON FIRE
RESPONDING OFFICERS STATUS
10:16AM CHP Unit Enroute
10:16AM CHP Unit On Scene
10:25AM CHP Unit On Scene
ADDITIONAL DETAILS
9:50AM RWY BLKED
