tapping into a spectra
fireboy
texas
Is there a way for someone to just tap into a Motorola Spectra from the accessory connector to run trunker? and if so what pins would they be? just curious cause I know you can set one up in RF Modem mode and it basically decifers the informaton like a discriminator right? just a theory, If someone knows it would make a nice little rig mounted somewhere out of the way.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Yes, there's a pin on the DB15 which you can use. That's what I'm doing right now.
It doesn't require the radio to be setup in RF modem mode.
I forget which pin it is but a service manual should show you.
I don't remember the details but you might need to hit the radio with RSS or CPS to enable the pin. It might be on by default ... I forget.
43g70
All I had to do is move the Speaker + wire from # 6 to # 11 in the DB-15 for Discriminator Audio.
It is has been working since last fall non stop.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Just found it in the service manual.
Pin 11 on the DB-15 connector is labelled DISC. AUD/RX-RS232.
No extra programming required.
ricky01
Hi Guys,
I also need to tap my VHF A5 Spectra to decode data transmissions, mainly railroad related apps. From the discussion above, and elsewhere, I've gotten the fact that I need to utilize Pin 11 for the detected audio. However, there are some other caveats that I need to tackle. To get a better idea of what I am doing, I need to have the discriminator feed output to a Griffin iMic, into my computer for the decoding process (done my a monitoring application on the computer). So I need the output to end up on a 1/8" phono jack, to plug into the iMic, routed USB to the computer..
So here are my assumptions. I need to take pin 11 to the positive lead on the jack, and bring the negative lead back to digital ground on pin 8. I think there is supposed to a capacitor in-line here on the postive lead, and possibly a resistor. If so, what are the values? and what other issues do I need to be aware of? My current DB-15 connector only has 4 wires in it. A jumper wire from pin 2 (Emergency) to pin 8 (dig. ground), a positive power wire to pin 5, and speaker wires to pin 6 and 7.
Any help would be greatly appreciated.
Rick
