Those freq's look like 464.9500 is a repeater, and the taxi's talk into it on 469.9500. If so, then you only need to listen to 464.9500(if this is a repeater, then you should both sides of the conversation equally well. If not, the be sure you have no delay set on either frequency.Action Taxi Dispatcher uses 464.9500 (Frequency) and the drivers user 469.9500 (Frequency) is there a way to put both frequencies together so i don't have to keep on flipping back and forth to listen to dispatcher and mobile units(cab drivers)
Most taxi systems run full duplex non-repeated.Those freq's look like 464.9500 is a repeater, and the taxi's talk into it on 469.9500. If so, then you only need to listen to 464.9500(if this is a repeater, then you should both sides of the conversation equally well. If not, the be sure you have no delay set on either frequency.
Yes, so to speak. It is a radio that has the transmitter and receiver built in. Used to be two separate radios.So he has two different radios in front of him?
