TCP/IP with motorola XiR M8668i
e0ne199
Hello everyone, I have a question about the capability of motorola xir M8668i at TCP/IP connection. Looks like I am going to get several of used radio with the same type as what I mentioned before and I would like to experiment on them by connecting all of these radios through TCP/IP network. As far as I know, smartPTT application is able to send files between radios using DMR signal alone from one computer to another. I know the transfer rate will be very slow since it will use DMR RF signal, but it does not matter since it is for experiment only. However, what I don't understand here is what type of connection is used to connect between the radio and the computer and which port should I used to connect both of them. Furthermore, I would like to implement this kind of connection with smaller linux-based computer by utilizing serial/uart connection between the computer and the radio. Do you know what kind of setup (cables, etc) I need to connect them, which port should I use to do this and and which software can I use to program the radio in order to be able to utilize TCP/IP connection? any reference (links, websites, etc) that you can provide here is really appreciated, thx before.
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
My understanding is that it is packet data based on CAI. A google search says it is related to CAI IP and it is an IP transfer.
Using this search term in google yielded some results "file transfer over dmr motorola radios"
TT
e0ne199
TT
hello, do you have any documentation (or at least some information) if motorola xir M8668i is capable of performing serial communication through its ports?
Project25_MASTR
TX-COMU
Texas
RDNIS. The interface is RDNIS. You can set the IP settings in TRBO CPS but you may have to enable some sort of modem setting like you do with P25 to pass that IP data through from the USB interface to the rest of the network. The RDNIS driver for those radios has been in the Linux kernel for well over a decade now.
e0ne199
can you recommend any link for using this interface with motorola, and is it limited to motorola only?
TampaTyron
Phoenix, AZ
