TDN9816A wiring info
cmjonesinc
I have a ht1000 12v vehicle charger and want to double check the wiring before I install it. It has a red, black, and white wire on the harness. I looked around and couldn't find a manual on it so I was hoping someone might know. I'm guessing red is 12v, black is ground, and white is ignition? Can anyone confirm this? Thanks in advance.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
function / color / wire size / fuse value
This is for a different Jedi charger that has ignition sense, but it should be correct for the wire you have as well:
1. A+ / RED / 18awg / 2 amp
2. PAC-RT / WHITE / 20awg / not fused
3. n/c
4. Ignition sense / YELLOW / 20awg / 0.25 amp
5. n/c
6. Ground / BLACK / 18awg / not fused
cmjonesinc
3. n/c
5. n/c
Thanks! I appreciate it.
