teacherspal
teacherspal
ocala,fla
to anyone living in marion county fla:
for the past week or so i have been unable to receive any transmissions on my pro 197
from thr ocala police dept.
has anyone had this problem?
any info will be appreciated
GADGET
exportdawg
exportdawg
GADGET
They could have changed control channels. I would program all these in and see if that takes care of the problem..imo
859.93750c
859.21250a
859.53750a
And throw these in for good measure
854.96250
856.21250
857.21250
857.93750
858.93750
khoelldobler
now residing in Ocala, Florida since 1999
GADGET
I live qith-in Ocala city limits, near the Ocala christian academy.... I pick them up just fine, keep in mind that they do alot of CAD dispatch and they are using Visionet services on thier computers/radios. Silent dispatching seems to be a big thing now a days, and you might start hearing less and less on thier radio system.
I have anylized thier trunk system using trunk anylizing software, and can confirm that the freq's have not changed, nor are they using a different control channel.
knurt asked this same question about a month ago, and here was my reply then.
Marion County as well as Ocala have begun using CAD ( computer aided dispatch ) and it's more noticeable lately. As morning passes, and the day gets busy, you will see them use the radio more often. To my knoweledge, the MC trunk system has not changed... and the new Ocala trunk system is correct, as listed in the database.
I have just begun a system decode check up for Marion's trunk system using Pro96com (a trunk system decoding software) and the following 9 (nine) frequencies are decoded, and make up the county radio system... check them against what you have in your scanner.
Marion System
851.5875 V
851.7500 V
851.8750 V
852.1250 V
852.2500 V
852.3750 V
852.7500 A
852.8750 A
853.2500 CONTROL CHANNEL
The Ocala trunk system I decoded today has a total of 10 (ten) frequencies, and make up the City radio system. Here is the current Ocala configuration, check them against what you have in your scanner.
Ocala System
854.9625 IV (transmits system ID information)
856.2125 V
857.2125 V
857.7125 V
857.9375 V
858.2125 A
858.9375 V
859.2125 A
859.5375 AV
859.9375 CONTROL CHANNEL
__________________
khoelldobler
teacherspal if you are available tomorrow, Sunday, swing by the house and I will be glad to show you the trunking anylizing software, easy to use, and you can use it on your home computer. I can also show you the pro-106 scanner programming software and the system I have in my 106 scanner. PM me if interested, I will be home all day tomorrow.
