teamviewer + TRX-1
np4r
Utuado,Puerto Rico
HI , Im usig a trx-1 scanner connected to my computer and with team viewer I can use the remote control program for my whistler . I can do all remotely with the scanner from my ipad but no Audio is passing through , does any one knows how to configure teamviewer so the audio can be heard remotely? or any pther program for that?
boy7777777777
Arkansas
You have to have an audio cable plugged in the headphone jack of the scanner and ran into the microphone jack up your computer for it to pass Audio. You also have to go into TeamViewer settings on your iPad and turn that option on. When you close TeamViewer you will lose Audio. If you are wanting to listen to it continually you will need a program to stream the audio.
