SDRTrunk Teardown - What is it and why do I have it
Kazzaw
South East QLD, Australia
Hi,
I have been having issues with Teardown appearing in my SDRTrunk instance.
I 'could' potentially be demanding too much from SDRTrunk, however I have had this running previously for 48hrs with no teardowns appearing (about 2 weeks ago). I then took my system away with me for a week, and didn't fire up SDRTrunk for another week. This week I have been having issues consistently.
What I'm trying to do:
I have 4x RTL SDR dongles.
Dongle 1 is monitoring a TIII CC, 160MHz
Dongle 2 is monitoring 2 TIII CCs, 418MHz range
Dongle 3 is monitoring 2 TIII CCs, 463MHz range
Dongle 4 is monitoring a TIII CC, 506MHz range.
It is worth noting that Dongle 2 and 3 are monitoring the same system, just different sites. Duplicate calls are disabled (as there will be quite a few across these sites).
Dongle 1 and 4 have a general 'unknown' talkgroup recoding preference, and 2 and 3 have some TG's programmed in with a general blanket (TG Range 1-max) as unknown as well.
My issue according to the LSN/LCN appears to be coming from Dongle 3, as all the teardown channels have the matching LSN/LCN for that system.
I'm stuck at working out what could be causing these teardown issues (and even if teardown is an issue or can be ignored).
My logs contain lots of entries, however they are all one of these 4 lines
20210617 104024.376 [sdrtrunk pool-1-thread-2] DEBUG i.g.d.r.AudioRecordingManager - Audio Segment detected with NO TO identifiers [1GB/1GB 66%]
20210617 104027.042 [sdrtrunk pool-1-thread-1] INFO i.g.d.m.d.d.m.d.p.PacketSequenceMessageFactory - Unknown Packet SAP: UDP/IP HEADER COMPRESSION - returning unknown packet [955MB/1GB 50%]
20210617 104146.884 [sdrtrunk pool-1-thread-6] INFO i.g.d.m.d.d.m.d.p.PacketSequenceMessageFactory - Unknown Short Data Packet Header Type - creating unknown packet. [825MB/1GB 43%]
20210617 103021.515 [sdrtrunk pool-1-thread-1] INFO i.g.d.m.d.d.m.d.p.PacketSequenceMessageFactory - Unrecognized IP Packet Version: 7 - returning unknown packet [673MB/1GB 35%]
One entry of
20210617 091558.686 [sdrtrunk pool-1-thread-4] INFO i.g.d.s.t.FrequencyErrorCorrectionManager - Auto-Correcting Tuner PPM to [0.4] [1GB/1GB 79%]
I am recording with Trunking Recorder
Any ideas? Laptop is a moderately spec'd 10th gen i5, 16GB ram.
Kazzaw
0.5.0-alpha6
Attached is startup log.
Code:
20:27:11.863 INFO  i.g.d.icon.IconModel - loading icons file [C:\Users\kazza\SDRTrunk\settings\icons.xml]  [11MB/254MB 4%]
20:27:11.869 INFO  i.g.d.icon.IconModel - Icons file not found at [C:\Users\kazza\SDRTrunk\settings\icons.xml]  [11MB/254MB 4%]
20:27:12.129 INFO  i.g.d.log.ApplicationLog - Application Log File: C:\Users\kazza\SDRTrunk\logs\sdrtrunk_app.log  [19MB/254MB 7%]
20:27:12.168 INFO  i.g.d.log.ApplicationLog - SDRTrunk Version  : 0.5.0-alpha6  [6MB/254MB 2%]
20:27:12.168 INFO  i.g.d.log.ApplicationLog - Gradle Version    : Gradle 6.3  [6MB/254MB 2%]
20:27:12.168 INFO  i.g.d.log.ApplicationLog - Build Timestamp   : 2020-10-26T04:29:57.816-0400  [6MB/254MB 2%]
20:27:12.170 INFO  i.g.d.log.ApplicationLog - Build-JDK         : 15 (BellSoft 15+36  [6MB/254MB 2%]
20:27:12.170 INFO  i.g.d.log.ApplicationLog - Build OS          : Linux (amd64 4.4.0-193-generic  [6MB/254MB 2%]
20:27:12.170 INFO  i.g.d.log.ApplicationLog -   [6MB/254MB 2%]
20:27:12.170 INFO  i.g.d.log.ApplicationLog - *******************************************************************  [6MB/254MB 2%]
20:27:12.170 INFO  i.g.d.log.ApplicationLog - **** sdrtrunk: a trunked radio and digital decoding application ***  [6MB/254MB 2%]
20:27:12.170 INFO  i.g.d.log.ApplicationLog - ****  website: https://github.com/dsheirer/sdrtrunk             ***  [6MB/254MB 2%]
20:27:12.170 INFO  i.g.d.log.ApplicationLog - Memory Logging Format: [Used/Allocated PercentUsed%]  [6MB/254MB 2%]
20:27:12.170 INFO  i.g.d.log.ApplicationLog - Host OS Name:          Windows 10  [6MB/254MB 2%]
20:27:12.170 INFO  i.g.d.log.ApplicationLog - Host OS Arch:          amd64  [6MB/254MB 2%]
20:27:12.173 INFO  i.g.d.log.ApplicationLog - Host OS Version:       10.0  [6MB/254MB 2%]
20:27:12.173 INFO  i.g.d.log.ApplicationLog - Host CPU Cores:        8  [6MB/254MB 2%]
20:27:12.173 INFO  i.g.d.log.ApplicationLog - Host Max Java Memory:  3 GB  [6MB/254MB 2%]
20:27:12.173 INFO  i.g.d.log.ApplicationLog - Storage Directories:  [6MB/254MB 2%]
20:27:12.173 INFO  i.g.d.log.ApplicationLog -  Application Root: C:\Users\kazza\SDRTrunk  [6MB/254MB 2%]
20:27:12.173 INFO  i.g.d.log.ApplicationLog -  Application Log:  C:\Users\kazza\SDRTrunk\logs  [6MB/254MB 2%]
20:27:12.173 INFO  i.g.d.log.ApplicationLog -  Event Log:        C:\Users\kazza\SDRTrunk\event_logs  [6MB/254MB 2%]
20:27:12.176 INFO  i.g.d.log.ApplicationLog -  Playlist:         C:\Users\kazza\SDRTrunk\playlist  [6MB/254MB 2%]
20:27:12.176 INFO  i.g.d.log.ApplicationLog -  Recordings:       C:\Users\kazza\SDRTrunk\recordings  [6MB/254MB 2%]
20:27:12.176 INFO  i.g.d.util.ThreadPool - Application thread pool created with [8] threads  [6MB/254MB 2%]
20:27:12.176 INFO  i.g.dsheirer.gui.SDRTrunk - Home path: C:\Users\kazza\SDRTrunk  [6MB/254MB 2%]
20:27:12.182 INFO  i.g.d.p.SystemProperties - SystemProperties - loaded [C:\Users\kazza\SDRTrunk\SDRTrunk.properties]  [6MB/254MB 2%]
20:27:12.182 INFO  i.g.d.p.SystemProperties - SystemProperties - application properties loaded [C:\Users\kazza\SDRTrunk\SDRTrunk.properties]  [6MB/254MB 2%]
20:27:12.200 INFO  i.g.d.s.SettingsManager - SettingsManager - loading settings file [C:\Users\kazza\SDRTrunk\settings\settings.xml]  [6MB/254MB 2%]
20:27:12.428 INFO  i.g.d.s.r.RecordingSourceManager - RecordingSourceManager - discovered [0] recording configurations  [10MB/34MB 31%]
20:27:12.539 INFO  i.g.d.s.t.TunerManager - LibUSB API Version: 16777478  [12MB/34MB 35%]
20:27:12.542 INFO  i.g.d.s.t.TunerManager - LibUSB Version: 1.0.22.11312  [12MB/34MB 35%]
20:27:12.557 INFO  i.g.d.s.t.TunerManager - discovered [9] attached USB devices  [12MB/34MB 35%]
20:27:12.560 INFO  i.g.d.s.t.TunerManager - USB Bus [1] Device [2109:2813] Hub Device  [12MB/34MB 35%]
20:27:14.353 INFO  i.g.d.s.t.TunerManager - USB Bus [1] Device [0BDA:2838] LOADED: RTL2832 SDR/R820T 00000001 Max Rate:38400000 bps  [14MB/34MB 41%]
20:27:14.353 ERROR i.g.d.s.t.TunerManager - couldn't determine RTL2832 tuner type  [14MB/34MB 41%]
io.github.dsheirer.source.SourceException: couldn't open device - check permissions Linux: udev.rule? , or Windows: reinstall Zadig? [LIBUSB_ERROR_ACCESS]
        at io.github.dsheirer.source.tuner.rtl.RTL2832TunerController.identifyTunerType(RTL2832TunerController.java:346)
        at io.github.dsheirer.source.tuner.TunerManager.initRTL2832Tuner(TunerManager.java:476)
        at io.github.dsheirer.source.tuner.TunerManager.initTuner(TunerManager.java:333)
        at io.github.dsheirer.source.tuner.TunerManager.initTuners(TunerManager.java:148)
        at io.github.dsheirer.source.tuner.TunerManager.<init>(TunerManager.java:79)
        at io.github.dsheirer.source.SourceManager.<init>(SourceManager.java:46)
        at io.github.dsheirer.gui.SDRTrunk.<init>(SDRTrunk.java:167)
        at io.github.dsheirer.gui.SDRTrunk.main(SDRTrunk.java:624)
20:27:14.359 INFO  i.g.d.s.t.TunerManager - USB Bus [1] Device [0BDA:2838] Unknown Device - Class 0  [14MB/34MB 43%]
20:27:16.145 INFO  i.g.d.s.t.TunerManager - USB Bus [1] Device [0BDA:2838] LOADED: RTL2832 SDR/R820T 00000003 Max Rate:38400000 bps  [15MB/34MB 45%]
20:27:17.892 INFO  i.g.d.s.t.TunerManager - USB Bus [1] Device [0BDA:2838] LOADED: RTL2832 SDR/R820T 00000004 Max Rate:38400000 bps  [16MB/34MB 47%]
20:27:17.892 INFO  i.g.d.s.t.TunerManager - USB Bus [1] Device [5986:9102] Miscellaneous Device  [16MB/34MB 47%]
20:27:17.892 INFO  i.g.d.s.t.TunerManager - USB Bus [1] Device [8087:0AAA] Wireless Controller Device  [16MB/34MB 47%]
20:27:17.892 INFO  i.g.d.s.t.TunerManager - USB Bus [1] Device [8086:02ED] Hub Device  [16MB/34MB 47%]
20:27:17.892 INFO  i.g.d.s.t.TunerManager - USB Bus [1] Device [2109:0813] Hub Device  [16MB/34MB 47%]
20:27:17.892 INFO  i.g.d.s.t.TunerManager - -------------------------------------------------------------  [16MB/34MB 47%]
20:27:17.895 INFO  i.g.d.s.t.TunerManager - USB Bus - Potential Maximum Data Rates  [16MB/34MB 47%]
20:27:17.898 INFO  i.g.d.s.t.TunerManager - USB Bus [1] Rate [115200000] bits per second  [16MB/34MB 49%]
20:27:18.947 INFO  i.g.d.p.PlaylistManager - Loading playlist [C:\Users\kazza\SDRTrunk\playlist\default.xml]  [16MB/38MB 43%]
20:27:19.104 INFO  i.g.dsheirer.gui.SDRTrunk - starting main application gui  [21MB/38MB 57%]
20:27:19.644 INFO  i.g.d.s.t.u.USBMasterProcessor - Starting USB master processor thread  [32MB/54MB 60%]
rlmurray56
Puyallup, WA
From the software author on the Google Groups site for SDRTrunk :
"Teardown is the channel state between when the call is ended and either a)the channel gets reset for the next call, or b) the channel gets removed."
Here is a link to the thread: What is Teardown?
Kazzaw
Thanks. Explains it a little more. Still dunno why it happens. If I drop all dongles back to 1 control channel each it seems to help. I'll keep an eye on it
