tropiradio
- Joined
- Mar 10, 2021
- Messages
- 198
Hope this will be ok to post here, as I could not find any other section that would deal specifically with wattmeters and/or the Telewave brand in itself. Since this is the section I usually post to, hope its appropriate. Otherwise please feel free to relocate.
I do have a 44A wattmeter and would like to get information on how the -40dB sample port is implemented at the factory to try and add one to my wattmeter to upgrade it to 44AP. Even some internal pictures of the unit showing the sampler port section would be useful. Assuming they use some sort of shielded broadband T attenuator, but I have searched up and down for this information and so far could not find anything. I mostly use VHF and UHF, so no need to design the sample port attenuator go any higher, although if I can build it to original specs it would be of course a plus.
Years ago I had a 44AP with the port already in place and always found it very useful to test among other things repeater desense and other measurements. Nowadays I mostly use the sampling T from my RF Industries adapter kit, but given it has variable attenuation depending on the plunger position, its a bit less convenient to use. Also have a small 65W dummy load that came with a separate sample connection that I got from a surplus parts sale, so there was no brand or model, much less datasheets with it. The port has about -40dB attenuation, but varies quite a bit (8-10dB) depending on frequency and band being tested.
Was thinking perhaps sending Telewave an email, but given that the 44AP model is now around 1.5K and up, imagine they would want a good chunk of cash for a retrofit sample port kit, if it even exists. So not sure the cost of a factory direct option would be justifiable.
Thanks in advance for any information.
