TerraWave 900 MHz 15 dBi Yagi Antenna
by IPC-STORE✅
Learn more: Amazon.com: TerraWave 900 MHz 15 dBi Yagi Antenna: Computers & Accessories
Price: $60.39 & FREE Shipping
"Ventev's TerraWave 824-960 MHz 15 dBi Yagi Antenna with N Jack is designed for applications in the 900 MHz frequency, including, radio frequency identification (RFID) applications, cellular systems, global system for mobile (GSM) communications, code-division multiple access systems (CDMA) applications, multipoint applications and wireless video links. The antenna's high gain and very narrow beamwidths enables long range connections. It can be mounted horizontally or vertically for the best connection. Includes heavy-duty steel mounting brackets and an N-style jack connector.
It's a 15dBi yagi antenna with 28degree horizontal/vertical beam-width. Fine tuned to 800-900Mhz range. I testing it at ground level now, this thing really pulls it in.
Testing it on a RTL-SDR with DSDplus fastlane for Digital p25 APCO phase 2.. So I can see the signal strength in real time graphs. I put it on a spinner base, so I can manually fine tune it with fast results. I just point it at the simulcast tower I want.. Great Antenna for digital around 800mhz! Can't wait to elevate it.
by IPC-STORE✅
