Terre Haute Casino Resort
cubn
Search, Listen and Submit
Marion/Johnson County, IN
Just wondered if anything is on the air yet and if so is it DMR conv, cap+, etc.
I have it in my scanner ready to listen if I ever get over that way.
usswood
Terre Haute, IN
It's on the air, and surprisingly in the clear right now! I can't get a decode on it from my home because of an ERS Tower 5 miles away and with-in that range of Freq's.... my trx decodes it as DMR and I have seen CC of 8, but I thought I seen 9 also. (Not much traffic right now at the time I'm in that area). I can confirm it is a resting DMR signal that changes between 464.150 and one of the other freqs (can't remember) about every 15 mins or so.... So not sure if it is Cap+ Con+ or DMR Tier III?
Have seen TG 1 also
What is that resting DMR signal usually associated with?
usswood
Terre Haute, IN
I have seen TG 1, 2, and 7 so far... all in the clear ..... TG 2 sounds like Housekeeping, but just not enough traffic at night to fully ID them.... At least until tomorrow! I have yet to have any ENC hits either. Control room calls itself "DISPATCH" go figure! LOL
usswood
Terre Haute, IN
Forgot to add also, both slots in use and the CC is different pretty much every transmission, so If that fits with the Cap+ criteria also?
INDaviation
D1 Hater
The 317
Sounds like Capacity Plus to me. If you have the LCNs and color codes for the frequencies then go ahead and it submit it as such.
cubn
A lot of Cap+ use the same CC on each frequency though they don't have to.
Thanks for posting your findings!
usswood
Terre Haute, IN
OK, I forgot when I set up the system, I selected "record" and this is what I have after going back and listening to small calls
CC is 7 and 8
TG1 - Security
TG2 - Slots
TG3 - Unk
TG4 - Only one not recorded, must be for the hotel?
TG 5 - Unk
TG 6 - Unk (might be grounds)
TG 7 - Floor Housekeeping - crews vacuuming different areas of the gaming floor
This is only my best guess so far... Pretty sure about TG 1 and TG 2 however!
AK9R
Staff member
Super Moderator
Central Indiana
Yep can we please see if a database administrator could put it on the website
okqy maybe a database admin could put it on the radio reference database
When the frequencies and talkgroups are confirmed by listeners, anyone can submit them to the database admins so that the database can be updated.
