That would only be effective under two conditions:
1. It's placed IN FRONT OF any active devices i.e preamps.
2. The interfering signals are outside the pass-band of the filter. If it's a notch filter, the notch has to be tuned to the frequency that's causing the overload condition and narrow enough to not filter out the desired signals.
The PAR filter for 162 MHz will pass power so it can be placed after a coax powered amp. I assume all the PAR scanner type filters are the same. I have the 152, 158 and 162 filters as well as a custom 930 MHz filter and they all pass DC.
The 162 PAR notch filter "may" help (I really doubt it will though) with the OP's wx intermod but that is about it. He is still going to experience severe overload, intermodulation distortion etc if he insists on using the amplified TV antenna as has been pointed out in the thread several times already.
The antenna the OP is using is about the worst antenna one could ever hook to a scanner.
I had the same antenna but hooked to my TV's as it was intended for. I was searching the bands one day with the scanners and kept finding what appeared to be birdies but I knew they were from an outside source.
I made a list and started powering things down. It was that darn amplified antenna radiating tons of trash from its own oscillator!
I junked the thing and ended up with an unamplified antenna for OTA and then I use an inline bullet amp when I do need amplification of OTA stations.
To the OP, what everyone has said is very true. What you are using for an antenna is going to cause WAY more issues than any benefit it will ever give.
Why do you think that your scanners S-meter is showing full bars at times even though there is no signal? That is a product of the cheap and noisy amplifier inside the antenna you are using and also a sign of overload of the scanner.
You will never get rid of the problems you are complaining of if you insist on using a TV or so called HDTV antenna that has an amplifier built in period.
Can you construct a wire dipole cut for the VHF range mounted under maybe one eave of your home? Something that is not really visible.
It would need to be vertical still but would work better than what you are using now plus it would at least get your antenna outside of the building and away from your noise generators like computers and computer accessories (modems, routers etc..) and TV's etc.
Before I could have an antenna on my apartment roof, I found that a simple magnet mount multi-band scanner antenna out on my balcony did a much better job over the stock antenna that came with the scanner.
Even setting a mobile antenna in a window that faces the signals direction can make a huge difference.
You may need to get creative with figuring out how to build and install some kind of antenna that does not look like an antenna. Using an amplified TV antenna like you are using now is going to cause big problems as you are already finding out.
There are books published for amateur radio operators that live in apartments or, god forbid, a HOA area with antenna restrictions. These books discuss how to build effective antennas for those in your exact situation. I think the ARRL even publishes one. Something like "Antennas for apartment dwellers" for example. You are not in an apartment but the same rules apply.
Almost all the V/UHF antennas in these books can be altered so they are more effective for the typical scanner frequency ranges.
Doing something like that is going to work better than trying to use your current setup.
You can try the PAR model VHFSYM(162)HT and it 'may' eliminate the intermod for the NOAA channel but as other transmitters come on, they are just going to mix and cause many other intermod products when using your current antenna. You will fight it until the day you get rid of that antenna.
Good luck with whatever you try!
