Here's my suggestions to try, in order:
1) Try a temporary run of coax from the loop to the power injector direct. Run it in through a door or window, using one unbroken length of coax, just for testing. This will have the coax & loop 'floating' with respect to earth, and eliminate any problems that might be being introduced by your adaptors & grounding of the coax. If it works significantly better... you're well on the way to sorting the problem.
2) Set up a radio that can be battery powered. Use it for a while and get used to how the noise sounds in this configuration. Then figure out a way to power the Wellbrook loop power injector from battery also - just make double sure the polarity is right! Now go ahead and turn off all mains power to your house, running the radio and loop from battery. Has the noise gone? If so, the noise source is in your house somewhere. If there was no change to the noise, it might be time to look for a better place to mount the loop. Generally, as far away from power lines and neighbouring houses is best - assuming your own house is not producing any RF noise.
3) Use that CATV or quad shield cable with some caution. They can only be used with crimp/compression connectors, as the aluminium braid can't be soldered to. Andy did recommend against using this sort of cable long term, as if any moisture get in, it can induce noise in the cable. Having said that, I have used a double shield 75 ohm cable - though with a real solid copper core and real tinned copper braid - without problems for over a year now.
And not that it should matter in this instance, but if you're looking for a simple way to improve your existing earth, just let a water hose drip some water around the ground where your earth stakes are located for a few days. Get the ground good & moist - that'd be the easiest & quickest way to improve its effectiveness.
Hope you get the problem sorted out... and share your solution once you have nailed it.
