RadioReference.com Forums
I hope someone can help me with this. I have had persistently bad problems with noise all the way from longwave to the 10 meter band. Across the board. I bought a Wellbrook loop because I have read about using the magnetic portion of the signal reduces noise, allowing you to hear weak signals. I am mostly interested in MW DX and tropical band DX but also want decent performance on the ham and broadcast bands, so the Wellbrook seemed like a good choice. Nothing doing, only the strongest signals can make it through the noise.
I can tell you how I set up the loop. It's on a mast on the southeast corner of my home about 15 feet in the air and about 10 feet from the corner of my house. There is a rotator. I used RadioShack 50-Ft. RG-58 Coax for the antenna, which goes to a grounding block. the block is grounded into two rods hammered into the ground (though the ground is so hard they protrude a foot or so). The two rods are coupled together the best I can. more RG-58 connects the block to the antenna interface inside. the lead goes to a Kenwood receiver and sometimes I couple it inductively through a copper loop to a Sony AN=LP1 so I can use it with portables. But this setup is not very successful.
One thing I was told to try but have not yet is rock salt buried next to the rods. It seems like an extreme measure but I am about to go there.
I have tried eliminating fluorescent lighting and getting everything away from power and internal power wiring. Nothing seems to help.
I have been told to try different cable. I will need to buy about $60 worth of the recommended cable. I am willing to do this, but just wanted a second opinion before splurging. I also worry that I've got too many converters in the path (bnc to pl-259 back to F for the grounding block, etc). I assume they are all opportunities for RF to leak in.
Should I try the cable? A different antenna to test? Move it indoors? Is there a way to test and measure the noise problem in order to isolate it? Do I need an antenna phaser or preselector? (I am also considering a second loop in conjunction with the first to null out the noise.) I am really tearing my hair out here!
Thanks for any and all advice.
