dispatchgeek
Control channel goes "brrrrr"
I am experiencing a new problem mid day that I have not experienced yet. We had some control channel shifts from primaries to alternates today as a result of scheduled site maintenance. I used DB search and noticed for the most part, the test function is failing to work as it has. It is not discovering signal on almost all of the sites I normally get CC and voice traffic on. This is the odd part: I can manually input the frequency into the P25 Frequency field on the P25RX config tab and get great decode on the sites testing "NOSIG"
1. Noticed on 2-10 1045, Also downgraded to 1-31 0648 with the same result.
2. Factory reset did not remedy the issue.
3. Antenna system is fine, reception is great when manually set.
4. Search worked this morning, broke at some point this afternoon.
I'm fairly stumped by this one. Any ideas?
