I was requested to setup a feed for the TDCJ Polunsky Unit (which houses death row) in Livingston, TX. Polunsky is in Region 1 which includes the Huntsville area which has 9 prison units. So there is a ton of correctional officers in the area that would like to be able to listen to the radio when off duty.
I am closest to the Polunsky Unit so it comes in good since they switched to DMR. The Huntsville Units are kind of hit and miss due to the low power DMR systems and distance. As the weather has started to cool off they are coming in better, especially in the evenings. When the leaves fall off the trees reception of them should improve.
I would like folks to check out the Rdio-scanner feed I have setup and give me feed back and suggestions for improvement, before I release the link to the general public. It is running on sdrs on a 3/5 element AY04 yagi.
