Hi folks, I am curious, is there any big advantage on having a tetra system vs a P25phase 2 system?
(And yes I know I could use AI, but I prefer humans who actually know what they are talking about)
I don't know a lot about P25, but I know the voice quality of P25 Phase two is comparable to DMR, and that it uses TDMA with two time slots with 12.5 kHz channel width. As such I'm going to talk just about the advantages of TETRA here.
TETRA uses TDMA with 4 time slots per carrier. Each base station can have multiple carriers. The smallest ones may support just two, but larger ones can handle 12 or even more and can be linked. Each carrier uses 25 kHz channel bandwidth. The number of time slots available simultaneously for voice or data is N-1. One timeslot is used for control messages.
TETRA has two general modes of operation. TMO and DMO. TMO is Trunked Mode Operation, and DMO is Direct Mode Operation. DMO is kinda like simplex when used as is.
There are some interesting features available with TETRA that I'm not sure if they are available with P25. DMO Repeater mode allows a terminal to act as a repeater for a smaller isolated area if needed, and Gateway mode allows a terminal to act as a gateway to provide coverage for other terminals. For example a vehicle mounted terminal in gateway mode can provide system coverage for handheld terminals that can't reach the site on their own. Can for example be used by police officers entering a building with poor coverage to gateway through their police vehicle.
DMO Repeater mode is a cost effective way to provide temporary repeater coverage using just a handheld terminal, or a mobile unit connected to a well placed antenna for example.
The voice quality of TETRA is a lot better than P25 Phase 2. After talking over DMR, that has similar voice quality to P25 P2 as mentioned, using TETRA is like night and day. It's not analog good, but it's not too far off.
TETRA terminals can also be used to make full duplex phone calls between terminals, or to the general phone network if linked.
The only real drawbacks I can think of in general is cost and 25 kHz channel width, and how complex even a simple system can be to set up.
And this is not even touching the security features of which there are many.
TLDR:
Pros: Voice quality, flexible operation.
Cons: Cost, complexity.
