thewraith2008
- Joined
- Nov 22, 2016
- Messages
- 1,853
Correct, no record capability exists. (and not likely to be added any time soon)Is this function not "ready" yet?
Latest version (v1.1.0.2) can be found in this post here: Download
The Airspy Mini should work fine.Can anyone confirm how well this is working with the Airspy Mini?
I have quite a few Control Channels in my area I would like to monitor, overall all Control Channels and Voice Channels are within about 6Mhz
Good stuff! Thank you.The Airspy Mini should work fine.
You will see about 4.7MHz visible bandwidth from the 6MHz in SDR#.
Airspy or Airspy-mini use 1 is good, but use 2, 3, 4 set to 6 MHz, those need connected to separate USB poort to prevent big crash nor decode tetra 6x RTL-SDR use 1 MHz, work fine on 1 USB
What SDR# version?I have upgraded to the Airspy Mini, I can now see all my CC/VC within the spectrum and getting pretty solid signals.
I have an issue which I cannot get my head around, even with the signals being strong I am getting very choppy audio on some CC/VCs even with a solid signal.
I have attached a screenshot of my Airspy settings, in case something is standing out, I have also attached a screenshot showing my spectrum, all these are my local CC/VC.
Sometimes when a call takes place on NetMon2 Voice Channel I don't get the solid received message but it is a strong signal and no matter how much I tweak the gains etc it struggles to stay solid. The 3rd Image called Tetra3 shows a good strong signal but the audio is breaking up bad.
Any ideas?
What SDR# version?
Hows is the CPU load for both PC and SDR#?
Have you tested the throughput of the data (from dongle) via USB.
Run the console test program from Airspy as described here: "Troubleshooting PC performance problems". (a bottom of page)
See if it's sustaining 6 MSPS.
Another thing to try is to lower the Latency (ms) value (in Audio side menu), try 50.
Not sure if it would make a difference with TNM.
SDR# 1700-1716 will probably be the best versions to use with TNM.
SDR# 1717-1777 will probably work, maybe colors are wrong. Not tested.
SDR# 1778-1803 not sure. Not tested. (probably same as below)
SDR# 1804+ will not work because of breaking changes in .NET 5. Maybe colors are wrong again.
SDR# made changes to the UI which made old plug-ins look out of place with themes.
Changes to plug-ins (some of the ones I updated) to look better in newer UI.
SDR# made changes again to the UI which made updated plug-ins look out of place.
Changes again to plug-ins (some of the ones I updated) to look better in new newer UI.
SDR# made changes yet again to the UI which made older plug-ins work again but the updated plug-ins look out of place again.
I stopped bothering to update because I'm bored with this repeating cycle.
