Texas Christian Univ.
jmayne
I am trying to understand the TCU radio system. I see that they have their own repeaters and frequencies listed here https://www.radioreference.com/apps/db/?fccCallsign=WQLK839. I have also seen references to their using MotoTRBO DMR.
Using the Uniden BCD536HP with the DMR upgrade and scanning the 18 or so frequencies as conventional I see the scanner display CAP -- for MotoTRBO Capacity Plus systems however when I program a system as a MotoTRBO trunk type and use the analyze function I get at most 1 LCN.
Any thoughts or suggestions on how to proceed would be appreciated.
Jim
IAmSixNine
Dallas, TX
Unfortunately the LCN finder is a very time consuming option and the slower the system is the harder it is to get right. North Park mall recently went from 4 conventional DMR channels to a cap plus and i never got past 1 of 4 after 2 hours of monitoring. SO i programmed them all as OFT DMR and just put in the talk group ID i wanted to monitor. I may try it again later.
I also think they enabled RAS because my Hytera and XPR7550 will not pass aduio for them now.
