There shouldn't
be any "chatter" on TAC and similar dynamic talk groups. One must understand the hierarchical structure of the talk groups to grasp the principles involved. It really isn't overly complicated, but honestly it is not explained very well, IMHO.
Let's examine a case example to illustrate. We are monitoring one of the static talk groups such as "Midwest Regional" (MR) and make a contact with one of the other users. If we two folks continue to communicate on that talk group, then we are trying up the resources of every repeater that has that TG as a static group. "MR" encompasses a very large area of six states. While I don't have exact figures let's assume there are 200 repeaters connected full-time to "MR", which is a reasonable guesstimate.
That means that the two people talking are tying up the time slots of 200 repeaters just to have a QSO, meaning that 198 other repeaters are tied up repeating their conversation*! That is a HUGE waste of resources. Instead, they should arrange between themselves to QSY (change) to one of the multiple "dynamic TGs" such as TAC311. Once they do that, then they are only using the two repeaters in their respective areas.
* Note that they are effectively denying the users of the other 198 repeaters use of that time slot by their actions.
I've actually heard two folks using the
same repeater in St. Louis, MO carry on a long QSO on the MR talk group tying up the ~200 repeaters for 20 minutes, when they should have simply switched to their repeater's LOCAL talk group!
Now consider the case of two folks using the Worldwide English TG. They are potentially keying up every repeater in the bloody world simultaneously! Again an exact number isn't available since that number changes hourly, but a reasonable guesstimate would be around 3,000... Wow, talk about a waste of resources!!!
Now all this was
before the proliferation of "hot spots"... Take the same example of two folks conversing on the MR talk group, but both of them are using "hot spots." If they switch to one of the available dynamic TGs such as TAC310 then they
won't be keying up any repeaters at all except for a few that may have had TAC310 activated and they hadn't yet timed out.
Hopefully all the above is clear enough, and explains why we should "use it, but not abuse it" with regards to static versus dynamic talk groups.
