The digital trunktrackers and STARS
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
We've had a wiki article out there for some time that (attempts to) document the trick(s) you need to use to properly trunktrack STARS -
Trunktrackers and STARS - The RadioReference Wiki
Right now all it has is Win96 data - I'm willing to bet newcomers wouldn't necessarily know what to do with the other digital trunktrackers. Would the actions and settings under ARC96 be the same? I would assume so.
I think - I could be wrong here - that with the object oriented scanners, that you can set the system up to essentially auto-populate, but it would be helpful to document how that gets done (what parameters do you set to accomplish this?).
What about Home Patrol, the PSR-800 and (presumably) the PRO-18? Once you download the data from the database, are there any other settings you need to change?
And of course, we can't forget the Uniden DMA scanners - what about those?
The more of these tricks and features that are documented, the more information you give a newcomer to these scanners...how about it?
best regards...Mike
