I finally got my R75 to stop misbehaving and going off and on at random but frequent intervals. It was so easy to fix: I simply threatened the radio with the dumpster.
Not really ... just kidding. What actually happened was this: Yesterday morning the R75 started acting up again, and finally quit altogether. I couldn't power it back on, and suspected that whatever component was starting to fail had finally died altogether.
It then occurred to me that it might have blown the internal fuse in the process, so I took the lid off and examined the fuse. It looked OK, but I decided to pull it and run a continuity test on it. Well, it was too easy to pull out of the holder, and I noticed that one end of the fuse wasn't sitting securely in its spring clip, but was instead resting on top of it. This was likely overlooked for a very long time, and causing intermittent contacts to the power supply. Once I pushed the fuse back in and made sure it was good and tight, the radio sprang back into service and hasn't failed at all since then.
So the cause of the problem was way simpler than all those theories that we explored over the past year or so. Kind of embarrassing, actually.
