If there flying low right over your head then a scanner that scans the FM Lo band as well as the UHF milair band is in order here. Also a scanner with Signal Stalker, Close Call, or Spctrum Sweeper function would help tremendously. A good non-stock antenna for a handheld such as the Maldol AL-500H will bring in the signal from a little farther in than was intended.
