prcguy
I recently came across a deal on a couple of UHF exposed dipole arrays to replace a dual band amateur antenna in repeater use. The dual bander is a copy of the Diamond X510 series, about 17.5ft tall with a VHF rating of 8.3dB and UHF of 11.7. I've been running this antenna on a UHF amateur repeater at my house for the last year and have mapped out its coverage fairly well, which is ok but not stellar. I also have a temporary use 2m repeater at my house and have used the VHF side of this antenna on the repeater with similar results, ok but not great.
One of the UHF dipole arrays I picked up has two 4-bay dipoles on the same mast with separate feedlines and since the dipoles are arranged in a row the gain is right around 9dBd with an elliptical pattern of maybe 100 to 120deg wide at the -3dB points. This is ok for my location due to the large hill on one side of my house and anyone using the repeaters would be away from the hill.
I took some precise receive measurements on the Diamond X510 clone before taking it down then compared to one of the UHF 4-bay dipole arrays after it went up. I was surprised to see signal strengths on some line of sight repeaters coming in between 5 and 6dB better on the 4-bay dipole array compared to the 17.5ft dual bander that supposedly has 11.7dB gain on UHF. 11.7dB over what? If its dBi then it would be 9.56dBd but that doesn't explain why an actual 9dBd gain antenna is 5 to 6dB better.
After the 4-bay UHF antenna has been up for a month I'm getting great reports of better signal strength in all areas and people can now use the repeater in areas where they couldn't before. This is a huge and unexpected increase in coverage from swapping out a 17.5ft antenna for an 8ft tall antenna, although the 4-bay is raised up to the same height as the top of the old 17.5ft.
I'm so happy with the improvement I dug out some Cushcraft VHF 2m dipoles I've had for years that were part of a 4-bay dipole array but I never had the mast or coax phasing harness. I refurbished the dipoles, built a 24ft aluminum mast out of some decommissioned antennas and built a coax phasing harness out of 75ohm TV coax and F connector T adapters. Today I completed this VHF 4-bay dipole array but not before putting the 17.5ft Diamond X510 clone, taking some precise receive measurements and find the new VHF 4-Bay dipole array is between 3 and 4dB better on the 2m ham band when mounted in the exact same spot.
So if the Diamond X510 clone is rated at 8.3dB and my new 4-bay VHF is 3 to 4dB better and cannot be more than 9dB, that means the X510 clone is really around 5dBd gain. So where do they get the 8.3dB rating? Bottom line here is the 4-bay dipole array is a winner and has the most gain you can get for its size. They are also pretty easy to make, so if you want some big performance ditch your foreign fiberglass crap and put together a 4-bay dipole array. You can find instructions for a VHF version in post #5 here: 4-bay VHF dipole array project
Here is a picture of my new VHF dipole array project with a lot of TV coax hanging off the back side.
