The NewF1000 / F2000 Series VHF and UHF Transceiver
publicsafetyradio
Mesa AZ
Compact, Slim Dimensions IP67 Waterproofing and Full of Useful Features
http://www.icomamerica.com/en/products/landmobile/portables/f1000/default.aspx
IP67 Waterproof and dust-tight protection
The IC-F1000 series has a 24.5mm (0.96 in) slim depth with IP67 waterproof casing. The transceiver can withstand 1m depth of water for 30 minutes. Its dust-tight construction prevents the ingress of powder dust, sand, mud and other objects.
Enhanced emergency with built-in motion sensor
With a built-in motion sensor, the IC-F1000 series can detect its position, state of motion and non-motion and can send an emergency signal. The motion function detects if the transceiver is moving or shaking, for example, during a chase. The lone worker and man down functions are programmable.
Selective calling, quiet stand-by and more
The IC-F1000 series has built-in 2-Tone, 5-Tone, CTCSS and DTCS signaling capabilities for group communication and selective calling.
MDC 1200 compatible
The following MDC features are programmable.
PTT ID
Emergency (No ACK transmission)
Radio check (RX only)
Stun/Revive (RX only)
Transmit status messages (LCD types only)
100 alias table (LCD types only)
Easy to hear in noisy areas
The large 36mm speaker of the transceiver provides clear companded 800mW* audio. The built-in BTL amplifier doubles the audio output power and delivers loud and intelligible voice to a radio operator working in noisy environments.
* Typical with internal speaker
Channel announcement
When you rotate the channel knob, the radio announces the channel number. Convenient for making radio adjustments without having to look at the radio.
Built-in inversion voice scrambler
The built-in inversion voice scrambler provides secure conversation. Up to 16 codes are selectable.
14 Hours of operating time
The supplied waterproof Li-Ion battery pack, BP-279 (7.2V DC, 1485mAh), provides 14 hours* of operating time.
*Tx:Rx:Standby=5:5:90. Power save function ON.
