The Official Latest G4/G5 Firmware and PPS Thread
Webodisk
Silent key.
Virginia Beach,VA
After updating to 1.3, there are now random beeps when someone starts to talk that happen when scanning trunking TG. I did add member lists as well but have no priorities set. Any help appreciated.
I had the same issue, somehow voice buffering prompt tone was checked
W4KRR
Coconut Creek
What are the exact issues you are having with your amp charger ?
I don't know if it has anything to do with the 1.3 firmware, but I have an intermittent issue where the audio disappears when the pager is inserted in the amplified charger base, but returns when the pager is removed. Sometimes it runs for hours with no issue, then the audio will just stop.
blackbelter
My amp was just replaced and so far the echo effect has disappeared . Updating to 1.3 has not been smooth thus far .
WX4JCW
Stow, Ohio
Anyone notice 3.16.22 went available for download today no new firmware but new PPS
N6ML
This is (I believe) a result of my pointing out that the dropbox with the beta release with the RR login fix had stopped working, so people could no longer download a version with that fix. The actual version is still V0.3.16 Beta 22.
trido
Southern In
On V0.3.16 beta 22 this is the info direct from UNI.
It makes no real changes that are worth advertising. It adds nothing its supposedly more stable.
Seth on your Post agree 100 percent I myself gave up went to 1.31.
I can and will Say Unication in
Taiwan
are working on the Unication Scanner as I did get an email from them on this.
Was going to post however at this time I have no detail I can share on the scanner model.
When I have details I will for sure share in the forum.
Where is 1.4 man I've been waiting 2 years it seems still nothing? This is ridiculous
trido
Southern In
Follow up:
Also I was told this new PPS ver fixed RR log in issues.
Jeff
Taiwan
JASII
Memory Capacity
If I try to import a large number of Control Channels and Alternate Control Channels from Radio Reference, will the Unication PPS catch any duplicates?
kc9neq
Illinois
What is the difference between PPS V00-03-16-Beta22 and PPS V00-03-Beta24.
I am currently using a Beta22 on a G5 with no problems.
wwhitby
Autauga County, Alabama
Taiwan
Thanks Jeff!
I've decided to wait on getting a G4 until I see what their scanner looks like.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
Feature request for the G4/G5 pagers: the ability to cut or boost the audio up to 3dB on a per-talkgroup (or per-frequency), in half-dB steps or better.
Not sure if it's been officially requested already or not. We've got several talkgroups around here which are either too soft or too loud, and a per-talkgroup/frequency audio cut/boost setting would be just the ticket.
