The Official site for Freescan 396 and 996. No more Yahoo groups
tampatracker
My conventional systems quick keys are not sorting at all, cpuerror. Am I missing something? I have multiple conventional systems.
cpuerror
Ontario, Canada
Ok I've reviewed some things and it turns out my test files were sorted by QK to begin with, so everything turned out ok during my testing. However the next version will address this.
wmbio
Cumberland, Md
Freescan backlight color
FYI...Seems the backlight color selected in Freescan .9C does not upload to the BCD996XT. I tried to upload 3 times.....the color white, and got blue. Changed it manually. Others are saying the same in the 996XT thread.
Wmbio
edgeman
Las Vegas
I just downloaded this program I love it. With the rebranding in Las Vegas, none of my other programs could handle the new band plans. I had no problems setting them up with Freescan.
Thanks for writing this thing.
cpuerror
Ontario, Canada
FreeSCAN 0.9D Available
This version incorporates fixes and improvements.
Direct Download -
http://scannow.org/files/FreeSCAN-0.9D.msi
.9D
-Volume and squelch settings are now saved and restored after full scanner clear
-By special request, added experimental support for UBC800XLT
-Sorting behavior has changed. Since I got about 10,000 emails about this, you can know sort by trunk
system QK. This works by sorting the site with the lowest QK.
-Improved channel editor
-Visual improvements
-Changed: New look for Windows-style virtual control screen
-You can now use the keyboard to interact with virtual control when using this interface
-When connecting to the RadioReference web service, your subscription expiration date is now shown.
-Fix: RR Imported conventional groups can sometimes show incorrect GPS coordinates
-Fix: Unable to set backlight colour for 996XT
-Fix: Issue with uploading bandplan to BCT15X
-Other bug fixes & improvements
KE4ZNR
Radio Geek
All of the updates/changes to the XT line look to be working great Assaf!
Thanks for all the improvements/changes you make to Freescan!
Marshall KE4ZNR
Direct Download -
.9D
N4DXX
In the pines where the sun never shines
Wrong username or password
Trying to program my 996t and i get that i have wrong username or password when trying to connect to rr database..My arc connects fine but as of right now its useless and when i close it and open freescan it won't connect it says check username password or make sure i am connected..Kinda strange but would appreciate some help..I do have the latest version as well
KE4ZNR
Radio Geek
Then that would be an authentication issue you have with RR.com not Freescan.
Marshall KE4ZNR
KE4ZNR
Radio Geek
Then why would my other software connect with no issues?
That usually indicates that a password is correct in one software and not correct in the other. A password incorrect error is an authentication error not a software itself error. All the software does is pass the Username & password fields to RR.com.
Double & triple check your password you have typed into Freescan.
Marshall KE4ZNR
N4DXX
Marshall KE4ZNR
I will and i also will disable my antivirus for a few and see if that helps..Will post update & thanks for trying to help me out here..
KE4ZNR
Radio Geek
No problem brother. We have all been there before :)
Let us know how it ends up.
Marshall KE4ZNR
N4DXX
Ok Marshall,I have tried everything i know to try..My arc logs in everytime and i have double checked my user id and password in free scan and still get the same message..I Dunno
KE4ZNR
Radio Geek
double check to make sure you have an exception for Freescan in your firewall/Virus protection...you may have an exception for ARC/Butel which allows it to connect but not one for Freescan...that is the only other thing I can think of.
Marshall KE4ZNR
N4DXX
Marshall KE4ZNR
Yep, Done that as well Marshall disabled my firewall and my antivirus,Still same message.I am sure i will get it figured out eventually..Thanks for your time..I was wanting to do some re programming and my ARC Has junked out and everyone at butel is smoking cigars while on vacation and now this..LOL
cpuerror
Ontario, Canada
I'm wondering what the exact message you are getting is ? At the end of the dialog box it will write out exactly whats wrong. Also, what version are you using?
