Nicholas440
After reading John's (KD8DVR) review and thoughts on the Puxing UV973 dual band hand held I purchased one, and I have to say that out of 6 Chinese hand held radios I have purchased the Puxing UV973 has quickly become my favorite of the bunch. I am very impressed at the audio quality and loudness of the transmit audio as well as the deep bassy sound of the receiver. I have other ht's that have dual watch on them and they will switch between two frequencies and listen for a signal, however, they will only receive one frequency at a time, whereas the Puxing has full duplexing, and can listen to 2 frequencies at the same time, and it allows you to adjust the volume of the "sub" band, or the opposite band that you are listening to. This works well when I am on a repeater and I am scanning the opposite band, if someone gets on it I will hear them both at the same time.
I have noticed on my other ht's that where the mic is they usually put a very tiny pinhole and on 3 of the units I have I have had to enlarge that pinhole in order to get a little more audio to the mic. It seems many of them don't even have the pinhole in the proper location in front of the mic, it's often way off to the side. The Puxing UV973 however has tiny slots where the speaker is and they utilize one of these slots for the audio opening for the mic which I feel is one reason why this Puxing has a lot more punch to the transmit audio than any of the others I own.
There are a lot of nice features on the Puxing that I haven't seen on my other radios, and cross band repeater is one of the great features of this radio. I liked it so much I ordered another Puxing as a spare, and I bought 4 of the larger 1600 mah batteries, because it comes standard with a 1200 mah battery and thats ok, it will run a long time on that providing you're transmitting on low power otherwise you'll use it up in a few hours time so the larger spare battery is a lot better and it's also 5/16 of an inch thicker than the stock battery and thats noticeable in your hand but feels fine.
I didn't think I'd use the cross band repeat function because I have a Kenwood TM V71A that I use, and I have set it up many times for one way cross band work. As long as I can hear the repeater I have no need for the cross banding radio to transmit back to me and I'm legal in that respect.
What I find myself doing a lot is there are 2 of my local repeaters that I use frequently, but if I am on any of the ht's I am noisy into the repeater unless I am in a hot spot inside, or go outside. So what I do is I set the Puxing on a window sill where the hot spot is, and its in the charging cradle, so I just make sure I'm solid into the repeater from that window, with the RH 901S antenna on the ht and I set it for cross banding, and use the other ht with 1 watt to use the repeater. It works amazingly well, and it does not have the double squelch tail that many radios have when cross banding because I'm only cross banding one way o there is no double tail . It also has a great solid transmit audio, and the people I've talked with did not know I was cross banding they all said it sounds loud and solid into the repeater.
I think this Puxing is going to be a good selling radio to rival the sales of the well known brands like the Baofeng, Wouxun, and a couple of the others. As far as I know this Puxing is the only one that does cross band repeat, and several other things the others wont do. Another nice feature is if I want to do a burst of DTMF tones for example to activate a function on the repeater or link up for our net I simply press the "Enter" button, and I get a DTMF window and I just punch is what codes I want then press the PTT key and the Puxing sends the DTMF tones in a burst which I really like.
There are several reasons to like this Puxing radio, and I've only mentioned a couple of them, and at $88 shipped to my door I think I got a good deal. These Puxings I bought I found on Ebay from a California seller, and I had them in 3 days from day of ordering so he's an excellent seller. The large spare batteries I bought from the 409.com shop because they had the 1600 mah battery at a great price.
Eventually I would like to do a video review of the Puxing UV973, and show all the features and what its' capable of doing. I could not find a video review that shows the Puxing in action.
