The state of Tennessee Advanced Communications Network (TACN)
jblackst
Knoxville, TN
Anyone monitoring around E TN today? Weird sites showing up as peers/neighbors: 03-25 769.36875 and 03-26 769.59375. (Knox Sharps Ridge, Cross Mtn and Windrock)
Also have a 01-91 851.00625 peer on Knox Simulcast and Windrock. This is a TDOC SOW?
Chasing down those 'odd' sites. 03-25 has the same CC as 02-46 Viking Mtn. 769.36875 is only licensed to TACN on two licenses.
Call Sign/Lease ID​
Name​
FRN​
Radio Service​
Status​
Expiration Date​
1WQLE432TENNESSEE, STATE OF (TACN)0004562856SYActive12/28/2029
2WQQK397Tennessee Dept of Safety0004562856SYActive01/14/2033
WQLE432 is the license for Red Stag (02-84) and Madisonville (02-23). That freq is on the license for the Madisonville site.
WQQK397 is the license for Viking Mtn (02-46).
Perhaps Viking Mtn is being changed to Site 03-25?
769.59375 is easier, it's only licensed to TACN at one site: Black Creek 02-39 (Scott Co).
Call Sign/Lease ID​
Name​
FRN​
Radio Service​
Status​
Expiration Date​
1WQQE559Tennessee Dept of Safety0004562856SYActive11/16/2032
Perhaps Black Creek is being changed to Site 03-26?
This brings up something interesting. For years, the only Zone 3 site has been Knox Simulcast. Is something in the works to move additional sites to Zone 3?
ka4bni
Dresden, TN
Call Sign/Lease ID​
Name​
FRN​
Radio Service​
Status​
Expiration Date​
Call Sign/Lease ID​
Name​
FRN​
Radio Service​
Status​
Expiration Date​
There are some sites in East TN that are and will be swapped over to Zone 3 this year. This is to balance out the number of sites between Zones 2 and 3.
bg_nashville
In investigating the drastic drop in traffic (not just THP) on the Holston Mountain (State) site, I discovered that there are two frequencies authorized and in use that are not in the database: 771.04375 and 774.13125. According to my archive, both frequencies have been used today. That last one affects the bandwidth spread and was outside the range I was operating my SDR. That could explain a small piece of the puzzle. Some TGs like Highlands Air and FTHRA Net Trans that were previously very active on that site are now virtually nonexistent. Highlands Air has a base right next to Holston Mountain. My working hypothesis is that they have temporarily moved the tower and/or antenna for work related to bringing on Carter County to TACN. The site currently has only about 10 to 15% (my best guess) of the overall traffic that it has had in the past.
bg_nashville
In the database, I noticed that TG 47159 has an alpha tag of "DOT HELP R2 T2" and a description of "Region 1 Tactical 2". Shouldn't the alpha tag be R1 instead of R2?
zachgallop
Knoxville, TN
I believe you are correct
Yes it is and I submitted it as “DOT HELP R1 T2” and “Region 1 Tac 2” I tried to get it corrected but that did not happen. Maybe you will have better luck. Someone else had it as TDOT District 8.
jblackst
Knoxville, TN
Yikes.
WIth a spread from 769.10625 to 774.13125 you'll need an Airspy or three standard SDRs to monitor all of that site. There appear to be 8 freqs on WQQE563, so I suspect there's another license out there for the others (perhaps a local govt?).
I travelled up I-81 last weekend and couldn't get linked up to Holston Mtn (State) from the interstate. Maybe that had something to do with it? I was figuring it might just not be 'viewable' from I-81.
bg_nashville
Yikes.
I use an SDRPlay RSP1B on that system. I always adjust the bandwidth down to only what is needed.
Holston Mountain is the premier site for radio and TV towers in Northeast Tennessee and Southwest Virginia. Something is definitely going on with it at the moment.
surfacemount
Knox / Roane / Loudon counties, Tennessee
Yikes.
That is part of the area I was alluding to earlier. Still don't know whose end the issue is on, but if you were having problems, kind of tells me without telling me.
KK4ELO
Smithville, Tennessee
Went through Cookeville today and picked up a new site. I noticed the last time I was through there, 2-65 was dead. I was bouncing between Sparta and Woodbury 800. But today, I was on 3-27, which is not programmed in my pager. CC 769.28125.
I don't have a way to get the NAC as I'm only there once a month. It's odd that it went to it wothout being programmed in. Whenever I go anywhere else near other sites not programmed, I get out of range.
jblackst
Knoxville, TN
There is an effort in progress to balance zone 2 and move sites into zone 3. It's highly likely the former 2-65 is now known as 3-27.
If the control channel was the same it likely ignored the RFSS and site id change?
jblackst
Knoxville, TN
This week's lucky site rezone appears to be Braden Mtn 700, from 02-71 to 03-31. But curiously in UniTrunker both sites with the same CC are showing as active peers on Cross Mtn.
jblackst
Knoxville, TN
It's the Weekly Wednesday scavenger hunt, locating the updated Zone 2 / Zone 3 site. There seems to be one every Wednesday over the last few weeks. At least they're consistent.
