I'm getting ready for a antenna project on my GMC AT4 and it was suggested to me to go with the Third brake light mounts. The concern I had was about a proper ground plane. I really did not see any real comments about it when I researched previous posts. Am I going to suffer alot of performance loss vs a roof mounted NMO?
Lopsided ground plane, will make the radiation pattern wonky. Even if you use "ground independent antennas", the existing ground plane will toss a lot of your signal to the stern.
I don't have a issue drilling, but this seems a bit less intrusive.
I've never used one, but I've read of people complaining that they have leaked on them. Water inside an expensive new truck would be way more intrusive that just drilling the holes.
Plus, if your 3rd brake light is LED, you'll have the antennas right up close to that.
The radios are going to be xtl2500s, one UHF and one VHF, any chance the proximity of the antennas with de-sense the receivers on Tx?
Yes. And the two antennas that close will wonkify your radiation pattern even more on UHF.
Also Any suggestions for antennas, going to buy new...
Larsen or EM Wave, accept no substitutes, and don't put Cheap Chinese Antennas on a nice truck like that. Same for the NMO mounts. Don't use Chinese crap to save a few bucks.
I'll probably get flamed for this, but here it goes:
These third brake light mounts are designed for people that are concerned that doing a permanent NMO mount is going to "reduce the resale value of their truck", which has been proven not to be the case. The off road crowd loves them since it requires minimal effort to install and they are usually looking for the "cool" factor rather than actual performance. I think I'd rather use a (gasp!) magnetic mount (gasp!) than use one of those third brake light mounts. At least with a mag mount, you could stick it in the middle of the ground plane.
It's a nice truck, and you want the radios to work well. Go all the way and do the permanent install. I'd do a VHF 1/4 wave and a UHF 1/4 wave. On a good ground plane, they'll have a nice radiation pattern, and they'll be nice and wide band, so you can use the full capability of the radio. Larsen NMOQ or the EMWave 1/4 wave antennas would be my choice.
