This is what cell phone tower interference looks like.
Anderegg
Enter text in this field
San Diego
Parked at my station under our parking lot mounted 100 foot cell tower...the local city 700MHz LSM Phase 1 trunking system coming in at an amazing -30dBm, with digital errors as high as 50. Thank you 4G. :-|
Ubbe
Stockholm, Sweden
You will probably not see that using other scanners than the SDS series. To get more or less perfect reception of simulcast systems you have to sacrifice other performancies in SDS scanners. The perfect scanner have not yet been produced.
/Ubbe
n1chu
Farmington, Connecticut
I thought RSSI readings were inaccurate, at best unreliable? -30DBm is a nice reading but is it a true reflection of the actual signal you want, or other splurious entities in a high rf environment? And the error rate... how did that affect the ability to hear? Was it unreadable? (I’m running under the idea these two readings are “ballpark” values, possibly not all that much accurate?)
Anderegg
San Diego
This cell tower will fade an APX at our main gate, which is in the radiation beam path of a few of the arrays! The SDS was below and out of the beam, but still...4G is a *****.
Paul
kb5udf
Louisiana
I wonder if you have the same issue I do in a few locations, First net down around 768 (give or take) and below). Giant wall-o-noise I can see on an SDR
R0am3r
Salt Water Conch
Oneida County, NY
/Ubbe
So only the SDS series radios are affected by cell tower transmissions while standing under the tower? Nice generalization.
R8000
Very Low Battery
My Whistler 668 just gives up on 700-800 MHz when I am within a mile or so of a cell tower. I never connected the dots until I was trying to monitor a analog 800 MHz smartnet system and heard it with my own ears. The noise floor just rose until the point the thing just stopped receiving.
