coolblueneon said:If you'd post what model number you have, I'm sure there are tons of people here that would help you program it. My experience with the RS associates has been dismal at best, so I don't trust the guy behind the counter just trying to make a sale. S/he may have said it was easy to program because s/he has done it 100's of times before. Don't forget to RTFM, and ask here if you have any questions.
Here we go again :roll:Bow said:Radio Shack... You Have Questions? We Have Blank Stares....
:shock:
eandjspc said:Well Im gettin out while I can this is not what I bought from the guy at RS "great Scanner" easy" anyways cant figure out the programming so Im going to get something I can use
Hi all I got the 2051 but I cant figure out how to do trunking and that I have my countys numbers they go like 861.2345 and such then there is a whole list of other numbers like 2098,2876, I dont know how to enter all of those please help tell me how to enter these on the 2051 and then i can work on the rest later I live in orange county florida orlando area thanks for any help
Ed
AZScanner said:I hate to say it, but the answer to his questions and more all reside within the pages of the manual that came in the box. :roll: All he needs to do is sit down and take the time to read
N6RFB said:In defense of Ed, I'm also having trouble programming my 2051 and I've read the owners guide over and over.
I have been trying to get the San Bernardino County, CA 06/07 System (Valley Areas) up and running with no luck. I have pulled my freqs and IDs from RR.
Here's my settings:
Type: E2-800
Freqs: 868.1625, 868.3375, 868.3875, 868.6125 (Control Code Only Mode)
CC Only Plan: PL1
No IDs locked out.
ID lists 1 thru 5 enabled (those are the only one's I used)
When I try and do an ID Scan the radio scans the freqs like it would if the bank was set up for conventional scanning. Hitting the search button won't change the display from "BANK" to "LIST". It works fine in Bank 1, my EDACS system.
I'm thinking the radio is not recognizing my ID list. I entered the DEC numbers I want to hear from the talkgroup list. Is that the correct number to enter?
Any ideas?
Dubbin said:Here we go again :roll:Bow said:Radio Shack... You Have Questions? We Have Blank Stares....
:shock:
AZScanner said:N6RFB said:In defense of Ed, I'm also having trouble programming my 2051 and I've read the owners guide over and over.
Here's my settings:
Type: E2-800
CC Only Plan: PL1
No IDs locked out.
Any ideas?
Richard,
Here's the difference between your post and Ed's: You stated the problem clearly and succinctly, and gave us all the information you could to help us help you. This is much better than "This thing stinks, I'm gonna go get a real scanner". Plus it's obvious that Ed needs to understand what the difference is between a talkgroup and a frequency. That most certainly IS in the manual of ANY trunking scanner and is very easy to find and read.
In regard to your problem, I don't think it's the wrong plan or wrong TGID's - I don't think it's getting that far. Sounds to me like it's hunting for a control channel and not finding one.
Do this: turn your squelch all the way down, then back up just enough to stop the "white noise" sound. Then, manually step thru each channel in that bank and see if you hear the control channel data coming thru the speaker - you'll know it when you hit it, you can't miss it. Sounds like a diesel truck at idle. :wink: If you scroll thru all the channels and don't hear one then you'll need to find out what frequency you're missing. Double check what you've entered against the RR database and google "San Bernardino scanner frequencies" as well to see what other sites are listing for your area. Enter any missing freq's and try again.
If you DO hear one, make sure the frequencies you've programmed are set up as trunked frequencies. I don't have a 2051 myself so you'll need to refer to the manual for the steps.
Let us know if that fixed it.
-AZ
