Thomas & Mack Info In RR DB or the April 2007 Ed. of the So. NV Scanner Book
The UNLVPD which has jurisdiction over the facility can be heard on the NSRS radio system and they usually use talkgroup IDs': 11-094 TMC Event Channel; 11-011 PD Secondary Dispatch; and sometimes 11-091 the Patrol Channel. More information on the EDACS TRS can be found in the database portion of this web site or by acquiring a copy of the Southern Nevada Radio Scanner Book, 6th edition which Amateur Electronics Supply in LV has current copies of. I found mine there today. The edition is dated APRIL 2007. The last edition was the 5th edition with a cover date of September 2006. Hope this helps you and others.
