You are being redirected... will give you gain and made for the frequency range you're looking for. Now if you want to spend the least with an OK antenna, but not great there's always
Ed's Antennas. Don't worry about getting a dual band or tri band antenna that covers the frequency range you need since it will still work fine there, just remember that more gain = more signal and when they indicate gain, dBd is 2.15 more than the same value expressed as dBi, and assume dBi if they don't specify how they're expressing their gain numbers.
Also, for receive, most of the VHF-Hi antennas will cover a much wider frequency range than specified. Generally they specify the transmit frequencies where SWR is really important. That said, if you can get your preferred antenna that specifically indicates where you want (such as Ed Fong's ham vs. commercial models) it may be best to get the commercial model since it's closer to your specified range.
