Hi everybody,
I'm in a bad location for reaching most of the local repeaters. I am in a very hostile radio environment with a lot of noise, and a lot of steel and concrete around blocking signal, with a bunch of trees out the only side of the building I have external access. I also don't have a way to mount an antenna outside (other than hanging it in my window), so that limits things even further. In addition, in one of my two external windows I have a J-pole hanging for my SDS scanners.
I have a 2m/70cm magnet-mount, mounted upside-down off the ceiling (because that's the only place I can really put it). My question is, does it matter if it's inverted? I'm able to hit one repeater site (and only one) about 23 miles away using around 2.5 watts on 2-meter, and one a few miles away on 70cm. I'm working on improving the antenna (addition of a ground plane, etc.) but I just wanted to get opinions on whether it matters if it's upside-down or not.
My thinking is it shouldn't matter too much. It's vertically-polarized so shouldn't make a difference from that point of view. On the emissions charts I know that in VHF most the energy is radiated horizontally off the active element, so that's good as well. Now, on UHF I have a few more concerns, though. UHF, of course, has several lobes because the UHF is operating using a harmonic, so I have a few lobes at various skyward angles, with still of course a large lobe emitting horizontally.
Except........because the antenna is inverted, the skyward lobes are actually now groundward lobes. So I'm going to lose a lot of that energy probably. So that's not good.
Also for clarity: That J-pole I mentioned is not for transmitting, it's just for the scanners.
Anyway I'm interested in thoughts anyone has. If the inversion is okay, I'll just construct a ground plane "under" (actually over) the antenna and call it good. Otherwise I'll need to re-evaluate my whole antenna situation and look for alternatives again.
