The reason you guys aren't hearing much is twofold: many/most scanner antennas aren't up to the task of VHF low-band reception, and the scanners themselves don't have real great sensitivity down on low-band. The Radio Shack 20-032 is a decent performer for low-band but even it can't hold a candle to a 1/4-wave whip cut to 42 MHz. Pretty much everything else out there (including the Laird/Antenex and PCTEL Maxrad "wide band monitor" antennas) is garbage as far as low-band is concerned.
I travel through Chattanooga/Knoxville up 75/40/81 twice a year. One year I did it with a Motorola Syntor X9000 programmed with THP receive and a Larsen NMO50 antenna. I heard plenty of activity, including the mobiles from several miles out. The difference between that and a Bearcat 780 with a Maxrad scanner antenna was.. well, night and day (the scanner heard nothing mobile and would only hear post/base communications within maybe a mile of the tower.)
If you're monitoring from a base station, I highly recommend buying or building a low-band ground plane or half-wave dipole antenna. If you're monitoring mobile you have more options: a commercial low-band base load antenna (tuning isn't critical, just get one for the 42-54 MHz portion of the band), the Radio Shack mag-mount previously mentioned, or even a CB antenna in a pinch. Then go through your scanners and see which one works best. You may find that older conventional scanners will outperform newer models on low-band. And finally, if you're serious about being able to listen look into getting a commercial radio to scan with. It doesn't have to be Motorola either; a Kenwood TK-6110 will work light years better than any scanner made, and the necessary programming hardware and software isn't hard to come by.
