Does anyone know the screw size for the empty threaded hole in the back of the radio? Is it 4mm? I want to use that hole for grounding my two BCD536HP radios in my shack. Thanks!
It means the screw that fits in the hole would be, Thread Diameter: 4mm, Thread Pitch: 0.7mm, Thread Length: 10mm
10mm is very close to 3/8 of an inch and that's the max they advise the screw should protrude into the hole. If your mounting into a thin sleeve, a m4 x 10 will be fine. If your going thru something thicker, you don't want more than 10mm or 3/8 going into the hole.
