Through the roof vehicle antennas for TK-7180H and TK-8180H
762mm
Hello,
I am planning on installing two Kenwood mobile radios (UHF and a VHF : the 8180H and the 7180H) in my Ford Expedition truck and was wondering what would be the best through the roof antenna type for such a setup. I have looked on Amazon and cannot find any through the roof antennas that have good reviews. Also, being in Canada, our Amazon selection sucks (like too many other things under our current regime, but I digress). I looked on Aliexpress and their offerings are few and of dubious origin/quality, as can be expected.
Preferably, I would like one antenna that can do both bands reasonably well with good range. I know about SWR, but have never tuned an antenna yet. Also, is there some sort of a coupler or A/B switch that would allow connecting two radios to a single car roof antenna? Is this even feasible, or is it likely to cause an issue?
I will be doing the work myself, so a straight forward solution would be best.
Thank you and I'm looking forward to your input.
Hello,
The solution that a professional would use would be a name brand NMO type mount permanently mounted through the roof. If you are serious about doing this right and making it look professional, you'll want to do the same.
Don't do magnetic mounts, trunk lip brackets, or brackets off the fender.
I use Larsen NMO mounts. I'll provide links for dealers in the USA, but these are extremely common products and you'll have no issue finding them in Canada.
You can find these products on Amazon.
I would NEVER buy them from Aliexpress. If you are going to drill a hole in a perfectly good vehicle, do not buy the cheapest Chinese antenna mount you can find. Do it right the first time.
Two separate antennas will work better, but you can use a diplexer to combine the two radios into one dual band antenna.
Not too difficult to do, and there's lots of public safety users using Ford Expeditions. You will need a proper hole saw to do this, and they are usually not the kind you'll find at the hardware store.
See below….
Here are some NMO permanent mounts that would be suitable:
Stick with Larsen, Laird or PC Tel mounts. Don't use any other brands. Do not use Tram, Browning or any of the hammy/hobby oriented brands. You don't want to use cheap mounts when drilling a hole in your roof. Even if it saves you a few bucks.
Separate VHF and UHF antennas give you more options and flexibility. You can choose the right antenna for your use case. I'd recommend going this route:
Quarter wave antennas permanently mounted on the roof of a vehicle will give you really good performance. They also provide a lot of useable bandwidth (work well over more spectrum). Good 1/4 wave antennas are also relatively inexpensive.
NMO mounts are the de facto standard in the industry, so when you install an NMO mount, you can choose NMO mount antennas from other manufacturers. I'd recommend Larsen or EM Wave:
For the 7180:
These two antennas are field tunable, which means you'll need to cut them to length. Since we don't know what radio service you'll be using these on, these are the generic recommendation. If you tell us what radio service/frequencies you are licensed to transmit on, we can make some more focused recommendations:
For the 8180:
The base design on the Larsen and EM Wave I linked to have excellent sealing design, which is what you want.
The antenna is the most important part of your radio system, so don't go cheap on the antennas.
There are higher gain antennas, which will focus the radiated energy more towards the horizon. Out in the flatland provinces, those might be a good choice. If you are in BC or mountainous areas of other provinces, the lower gain 1/4 wave antennas can actually work better.
But there's a trade off:
Higher gain antennas focus more power at the horizon, which will get you a bit more range, but the higher gain antennas have less useable bandwidth, so you may actually lose some performance.
Lower gain antennas, like the 1/4 wave type, have a more globe like radiation pattern, and that can be beneficial in the mountains or large cities where repeaters may be well above you. The focus less power at the horizon, but have much more useable bandwidth.
If you want to do a dual band antenna, or one antenna for both radios, we'd need to know what portions of VHF and UHF you are licensed for. That'll dictate which antenna. But here are some examples:
This is a pretty good antenna, I ran one of these for year on the amateur radio bands:
If you are a commercial radio user, you'd want one designed for the commercial portions of the VHF and UHF bands:
To run those dual band antennas into two separate radios, you need to use a diplexer. That will combine the two radios into one antenna feed:
You need to drill the hole. It needs to be 3/4". You do not want to use a hole saw designed for wood on the roof of your SUV. That risks tearing up the sheet metal and making a mess.
I use one of these:
Expensive, but I do enough that it pays off. It won't drill too deep and hit the headliner. It's the right tool to use, but the cost is kind of hard to justify if you are only doing one or two holes.
You can have a radio shop do the antenna install for you. That might make sense rather than buying the hole saw yourself. Plus a good radio shop will tune the antennas for you, install the connectors on the coax, etc. That can be worth the cost….
If you do want to tackle this yourself, and you do not want to spend the money on the professional hole saw, I've used one of these in a jam:
It does not have the depth limiting feature, so make sure you are careful.
You also need to think through -where- you install the antennas.
The antennas want to see at least 1/4 wavelength of ground plane (metal) directly under the antenna. So for your VHF antenna, you want at least 19" of metal in all directions under the mount. It does not have to be in the center of the roof, but it needs to be at least 19" in from any edge.
On the UHF side, you need at least 7" or 8" of metal under the antenna.
If you do the dual band antenna, then you want at least 19"….
Usually people will put them down the center line. Doesn't have to be, but it's aesthetically pleasing for some.
You also need some spacing between the two antennas if you go with separate antennas. I'd recommend at least 2 feet or more between them.
You don't need to remove the headliner to install these, they will install from the outside. A few simple hand tools are all you need.
Usually you can pull the weather stripping off above the door and you can see above the headliner. Just drill the hole and fish the cable over to the side and grab it. Route it between the roof and any side airbags. Route the cable down the pillar behind the door and under the trim to the radio. Cut the cable to length (leave a few inches of slack) and install the connector.
The 1/4 wave antennas can usually be tuned pretty well by cutting the whip to the length that is listed on the "cut chart" included with the antenna. The 1/4 wave antennas have a lot of bandwidth, so even though it's not exact, it will get you close enough to work very well.
If you really want to check SWR, you'll need a suitable SWR meter or a NanoVNA type tool to do that. We can leave that for another thread.
Do it right the first time with quality components and you'll never regret it. I'd never do anything but that on my own vehicles or the ones at work.
Don't forget the power for the radios. + directly off the battery. Negative off a grounding point adjacent to the radio. But that's a whole other subject.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Hello,
What are your use case for the radios? Ham radio? Commercial? For VHF this will make a huge difference on the antenna I would recommend. What part of the country are you in? Prairies of Alberta, Saskatchewan or Manitoba? Mountains of BC? Narrowing down your location and the highest and lowest frequency you will be using on VHF will definitely influence what I recommend for antenna. What @mmckenna said though is all spot on advice you should take seriously.
762mm
Wow, that's a whole more info that I was expecting. It's a gold mine. Thank you very much !!!
To clarify, I am licensed for commercial UHF radio in the 410-420 MHz range, for work purposes (I manage a public safety department). I wish to install a UHF that's tuned to our two repeaters and simplex channels, so that I can be in communication with our central in times of emergencies, phones being down, etc. I have a portable 5W Kenwood radio, but it is pretty useless outside of the town where I work.
The VHF is mostly for weather stations, listening to some HAM stations, marine channels, etc. The VHF radio is more of an afterthought, in case I need to communicate with other departments who are on VHF in times of need, etc. I've got a bunch of good VHF mobiles and the truck has room for it, so why not.
The truck is an SSV package (ex-police) and already had some holes in the roof that I had to fill with automotive glass adhesive when I bought it, so getting holes in it shouldn't be a problem. I have a bunch of Milwaukee hole saws for sheet metal already. When I get all the parts and the weather cooperates, it's gonna be "drill baby, drill" time! :)
The terrain is mostly suburban and mostly flat, with few tall buildings and a few small hills here and there. There are boulevards, highways, overpasses and a 1-mile long bridge in the way that goes across a local lake. A pretty typical US / Canadian suburban setting.
OK, so that means the 'field tunable' antennas I linked to are what you want.
The mobiles will give you some more range over a portable outside the vehicle, but the actual range will depend on the repeater system.
Sure. So the amateur radio frequencies start at 144 and the marine/weather frequencies are 163. That's a good application for a 1/4 wave antenna as it has plenty of bandwidth to give you good performance across that range, and then some.
Those antennas will be fine. You can go to a higher gain antenna if you want, but it probably won't make a huge difference in range. Usually you can look at what the public safety agencies use around you (or on your own departments vehicles) to get a good idea of what works well in that environment.
Bigger issue for some is the overall height. If you part your vehicle in a garage, or go into parking garages, drive throughs (Timmy's!!!) or the like, the shorter antennas are ideal. Also good for low tree branches.
Higher gain antenna are longer, will hit garages, drive throughs (Timmy's!!!) or tree branches more often. Plus it really makes the vehicle stand out.
Earlier, you talked about using a single antenna for both radios.
The commercially available dual and triple band antennas won't cover down to 410MHz. So you really need the two separate antennas. Since your ride sounds like it already has the holes in place, that makes it easy.
Ultimately it's cheaper, the dual band antennas (if they made one that worked down here) plus the diplexers, gets pretty expensive. Having two separate antennas really works better and gives you more flexibility.
762mm
Thank you very much! I think this is what I will go with, namely two separate antennas...
I will start with the UHF installation of the 8180H first, then add the other VHF radio maybe next summer. As I said, the VHF is more of a gimmick for me and the UHF is the business end.
I already ordered the Larsen mount from Amazon Freedom (US), as our Amazon Maple doesn't have it over here. I also checked GPS Central Calgary's website as mentioned above, but it was special order. I haven't ordered an antenna yet.
If I were to order an NMO-type UHF antenna for the 410-420 MHZ range and wanted the top of the line gain, what would be the #1 option on the market? I don't mind a tall antenna unless of course it's ridiculously long, but I'd prefer something about 3' max. I do lots of highway driving and I know that the very long antennas tend to cut through the wind and make a lot of noise due to drag.
Also, I do go to Timmy's a lot. Fortunately, our local Timmies don't have drive-throughs with low clearance and my behemoth of a truck doesn't fit in my garage anyway... She's a BIG gurl!
tweiss3
Is it time for Coffee?
Ohio
I use PC Tel BMWU4002S, which is a 12" half wave antenna that has a bit of gain, and a spring base. It claims 4.1dbi with a ground plane.
kayn1n32008
Sector 001
Big fan of EMWave myself. The VHF wide band 1/4 wave has done me quite well, used for both transmit and receive from 144MHz to 174MHz over the years I've had it.
On UHF EMWave has decent options as well. Either 1/2 wave or 1/4 wave will do you just fine. If you are only interested in your LMR repeaters and any simplex frequencies, I'd put a 5/8 over 5/8 wave colinear on the UHF radio.
For UHF a 5/8 over 5/8 wave fits the bill quite nicely..
I used a Larsen NMO2/70 with an open coil in the middle and it didn't generate a whole lot of road noise.
Less timms, more 7/11. It's way better coffee.
nokones
Sun City West, AZ
I would stay from the discount multi-product warehouse operated type businesses that do not specialize in professional radio components. Companies like Arcadian Antenna, Talley, and the Antenna Farm is your best bet for professional grade antennae such as Laird/T E Connectivity, Larsen, Pulse Electronics, and EM Wave. I would also stay away from the amateur and non-professional lower quality grade antennae.
About 5dB gain is the most you'll see for a legit mobile antenna.
Those 2 are about 40 inches tall, so you would want the model with the spring. On top of a tall truck, you may have some long term issues. I'd carefully question your own need for higher gain in this sort of application. The difference between a shorter/lower gain antenna versus the taller/higher gain model likely won't result in any noticeable difference in performance.
I'd consider the 5/8 wave Larsen. It's 3dB and shorter. But shop around for the best price. You can find similar 5/8th's wave antennas from EM Wave, PCTel, Laird, etc. for less money. Antenna Farm seems to be getting expensive, lately.
But, I ran a 5/8th's wave for a while on UHF and didn't find any real noticeable difference in performance compared to a 1/4 wave in my application and in my hilly area. Just wasn't worth the extra length on top of a tall truck for my needs. Plus, like I said earlier, the lower gain antennas have more useable bandwidth, which can be useful and shouldn't be overlooked.
Unless you know for sure that you need that tiny little bit of extra advantage, I'd go with the 1/4 wave. There's a BIG price difference. A basic 1/4 wave is cheap, and if it does everything you need, you'll save a lot of money. If it doesn't, you are not out a lot of money, and it's always a good idea to have a spare antenna.
762mm
Thanks for the antenna tips! I've searched to buy the "Laird Technologies B4063S" through Google from a vendor in Canada (any vendor), and the only result is some dubious website called "vianiche.com", link below :
Price is good. Too good. According to Google review searches, this website is deemed "not safe" with numerous red flags. I can't tell you how much I hate living in this inferiority complex sub-standard maple soycialist hellhole. Everything is 2x to 3x more expensive, the selection and availability is total crap, citizens have government-granted privileges and no actual rights, taxation is out of control, plus our famous "free healthcare" (not at all free, btw) will either kill you in the waiting line or offer you euthanasia for depression. We're slowly but surely turning into post-WWII Eastern Europe, but we keep voting for it with such "elbows up" enthusiasm. I need to find me an American girlfriend and marry her ass to get that US citizenship and escape, lol! (rant over)
But I digress, again... Case in point, I can't get it unless I import it. Or pay a middle man 2-3x the price, lol. Which I will end up doing, most likely.
"Oh, Canada... we stand on guard for thee taxes & customs fees!" That whole 51st State business doesn't sound so bad, to be honest. Nay, it actually sounds quite good all things considered. This antenna availability is just an example and a reflection of a much bigger issue we have.
:sneaky:
Thanks again for the detailed information, now I most definitely know what to get.... and what not to get. My next mission will be to find a way to source one of these antennas without getting scammed too badly for the "privilege" of living North of the 49th parallel, haha!
(y)
Yeah, reading their "about us" page raises all kinds of red flags. And the price IS too good. Run away.
This site is one of the few breaks we get from the political opinion storm. Please take it elsewhere.
Thanks again for the detailed information, now I most definitely know what to get.... and what not to get. My next mission will be to find a way to source one of these antennas without getting scammed too badly.
Unless you want the "look" of that antenna, I'd really encourage you to start with the 1/4 wave. Public safety radio systems are designed to cover their operational area for hand held radios. With a good 1/4 wave antenna mounted on top of your truck, you are going to be way out in front. Plus, they are much cheaper and easier to source.
mrweather
There's nothing wrong with the Larsen 5/8 wave UHF antenna. I have the the NMO4303CS for 70cm ham and it works great.
I bought it at Radioworld and while they mainly focus on ham gear (thus the NMO4303CS), they should be able to source you lower-frequency one.
FKimble
Newnan, GA
When comparing antenna numbers, don't forget there is a difference between DBi and DB. DBi is used a lot for marketing purposes because it give a 2.14 larger number. Subtract 2.14 from the BDi number to get the real DB number.
Frank
