I am planning on doing home made ladder line (4 inch). It will of coarse- have to come through the wall at some point.
I was thinking of taking some brass 1/8 rod- cutting it to stick out about an inch on each side of the wall--- thread the ends for nuts. Maybe slip polyethylene tubing over the rods and then maybe some rubber vacuum line over that . Then a bit of caulk on both sides - and maybe a plastic box over the outside. does that sound like it would work ? Im trying to avoid using coax through the wall. how does one terminate ladder line if it runs to the back of the radio or wattmeter or whatever the first piece of equipment is ? Is there no other way than transitioning to coax ?
