I was off Denton too, came pretty late about 2pm as I had to attend a party, luckily my nephew saved a spot for me.
Bird show was better SAT they flew it differently and didn't make as many passes over the off base crowd ,,, Also strange to see them taking off single file, never seen them do that before, they didn't FRI or SAT. Must have had something to do with operating with close or at minimum runway requirements with the main one closed down.
Hung out quite a while for takeoffs and had quite an odyssey. Wouldn't do any good to just stay where I was, got to get under them. Old factory entrance was barricaded so I turned back around illegally, and the Ecorse entrance was blocked.
So I went up to Michigan and came back down Denton and sat there for awhile, frustrated as aircraft were leaving far away from where I was. Got back on the freeway and just pulled off to the side, a couple Texans flew right over but I couldn't stand just sitting there on the freeway so I went up another exit and this took me on the airport service drive.
Found a spot where the Hueys were flying and sat there for a while then calculated if I could get up just a bit further I'd be on the flightpath. Road was blocked, was told I could either turn around or just go through the airfield and leave with the rest of the show traffic.
I turned back around and found a decent spot by an abandoned factory and watched the B-24 land right over me.
Security bounced me from there, saying the decrepit, weed and litter filled parking lot was private property. So I said screw this, I finally found a way back to 94 and started to head for home and came upon Rawsonville.
This used to be the spot of choice back in the day, haven't been that way for years so I figured I'd give it a try, and that was the spot to be. Saw quite a few nice takeoffs, was there up till 7pm and the Tbirds never did take off, probably in the morning.
Look forward to Selfridge, you know my spot there don't you Ski ?
