DSDPlus TIER III Help
Annunaki
I see LSNs / channel numbers in the event log window and the channel activity window.
Where? Because all I see is radio ids (Source and target)
Please copy and paste an example from my console log.
Cheers
Annunaki
Ok I think I understand this now....
33 is the CC which is slot 1 on 440.200
34 which is slot 2 on 440.200
143 which is slot 1 on (to be calculated)
144 which is slot 2 on (to be calculated)
I will have to wait a couple of hours to try it out as its 5.30am and I dont think the mrs would appriciate me firing up my machine at this unholy hour.
Annunaki
Ok cool I understand this now, I did not think or understand that CH in the channel activity window was the actual LSNs.
Anyway using thie below inside the DSDPlus.frequency data file fmp24 will trunk to and from 33/143 as needed.
Code:
TIII, 2, 1.1, 33, 440.200, 0.0, 0
TIII, 2, 1.1, 143, 440.8875, 0.0, 0
Now my question is do I need to add the 2nd slot into the DSDPlus.frequency data file? As I already see in the channel activity window it is already displaying the correct frequency for the 2nd slots.
cg
Connecticut
Earlier, you posted a screenshot with the neighbors. You can calculate the frequencies for those control channels and then populate the DSDPlus.SITES file to properly show the information.
chris
