I'm not sure if this has been discussed already but I've discovered something odd with Tier III systems regarding the LCN numbering. I have a fairly active TIII system near me that I logged for a while with DSD+. I gathered all the system frequencies, LCN order, color code etc (and noted that RAS was active) then put it all in the SDS. And received nothing. Not a peep. After lots of double checking I figured it was either a RAS issue or something with the LCN stuff, so on a whim I ran the LCN finder for a while. After discovering most of the LCNs I compared values with what I had from DSD+ and discovered something odd. All the values the SDS came up with were half of what DSD+ showed, across the board. In fact I noticed that I could take all the LCN values from DSD+ and just divide them by 2.. and in each case it would come back as a fraction (IE 488.5) so I would just drop the fraction for each one. I updated everything in the radio and away it went... works like a champ (maybe the 436/536 are like this too? I dunno)...
So I guess my next question would be regarding the database.... should we be submitting the values from DSD+ or the Uniden happy values?
