DSDPlus TIII (MOT) Stun vs. Unstun Decode
IMPRES2
I've noticed that on a Motorola Capacity Max Advantage system the Stun/Unstun is decoding opposite of what I would expect:
I'm currently running DSD+ 2.303, but I have seen this on previous versions as well.
I've confirmed the same decode is seen regardless from where the Enable/Disable is initiated (Sub-to-Sub, Console-to-Sub, SAC-to-Sub).
A radio Disable decodes as:
Reg/Auth/MS Check; Tgt=<Initiating-ID> Src=<CSBK>
Unstun; Tgt=<Receiving-ID> Src=STUNI
A radio Enable decodes as:
Stun; Tgt=<Receiving-ID> Src=STUNI
IMPRES2
Radio Disable
SYS_Parms: SysCode=11.10.0011111101; Registration req'd; CSC=0
+DMR slot1 BS DATA DCC=10 CSBK ECC/RAS Aloha SysCode=11.10.0011111101 AB; Networked; Registration req'd
+DMR slot2 BS DATA DCC=10 CSBK ECC/RAS Aloha SysCode=11.10.0011111101 B; Networked; Registration req'd
+DMR slot1 BS DATA DCC=10 CSBK ECC/RAS Ahoy Reg/Auth/RadioChk RID=1001 Src=2751
+DMR slot1 BS DATA DCC=10 CSBK ECC/RAS Ahoy REVIVE RID=1002 Src=STUNI
+DMR slot1 BS DATA DCC=10 CSBK ECC/RAS ACK AUTHENTICATION Tgt=1002 Src=8346601
+DMR slot1 BS DATA DCC=10 CSBK ECC/RAS ACK MS ACCEPT Tgt=1001 Src=STUNI
IMPRES2
Radio Enable
+DMR slot1 BS DATA DCC=10 CSBK ECC/RAS Ahoy Reg/Auth/RadioChk RID=1001 Src=30735
+DMR slot1 BS DATA DCC=10 CSBK ECC/RAS Ahoy STUN RID=1002 Src=STUNI
+DMR slot1 BS DATA DCC=10 CSBK ECC/RAS ACK AUTHENTICATION Tgt=1002 Src=3778703
