In about a year from now, I'll be retiring and one of several things I look forward to is enjoying listening to the scanner. No broadcasting, but having a CB would be fun I think. I'm in a city now, with 2 SDR dongles and this antenna mounted about 15ft off the ground.
I'll be in a rural area of NE Arizona - Lakeside/Show Low area. My land is at the edge of the forest so there will be about 100yds/meters of pine trees between the antenna and the clear area of the surrounding towns.
My "shack" will be the corner of a metal building. I don't really want to mount the antennas on the roof (unless you tell me there is a significant upside), instead I'm leaning to a tilt over mast design. I like the ability to lower it for maintenance, the inevitable upgrades, etc. I'm also planning ahead so at 70, I won't be risking life and limb messing with it on a roof.
My other hobbies are metal working/fabricating/welding - so the construction of one is pretty well in my wheelhouse, at least by looking at all the designs I've researched so far.
So, on with the first questions...
1] I get quite intimidated reading the other threads regarding grounding/bonding and the like. Are most licensed electricians savvy with the ins and outs of working with antenna installations (the electrical safety side of things)?
2] I'm not going to go crazy with the height, 30ft is where the dart I threw landed. That will still be below the treetops. Am I doomed with this setup for the ability to listen to local municipalities and such? My property is up on a hillside so I'll have that as a bit of an advantage.
3] I want to get a better scanner antenna - discone or the like. I know it's been asked a zillion times, but if you made it this far - I'd appreciate recommendations on the latest and greatest, or the tried and true designs to consider.
Well, that's enough boring for now. Thanks in advance for any and all critiques, advice, and assistance.
