Tippecanoe County TRS Listeners, Input Needed
scannerfreak
Moderator
Indiana
All,
I have a request to change the current LPD alpha tags from the current to the following:
30928 LPD-Ch 6
30960 LPD-Ch 3
30992 LPD-Ch 4
31056 LPD-Ch 2
31248 LPD Ch 5
I am inclined to leave them the way they are as they are more descriptive, however, if it would make it easier or better for listeners of the system I am all for it. So, I was wanting your guys input on this.
Thanks!
KD4YGG
I've noticed a change in them using channel numbers versus the alpha tags currently in the database.
I would suggest changing the alpha tags, but not changing the descriptions of the talkgroups - they are pretty much the same.
TippeTrunker2
Lafayette, Indiana
LPD still use both ways to ID their channels. Slow and formal you might hear them use the channel numbers. Fast and furious you will hear the older Alpha Tags.
