Tips for Rx Improvement capabilities for G4/5?
jetpm
Hey all,
I got a G4/5 for two tone paging on a conventional frequency. Currently I have it set to trip on low squelch and not using a PL. Sometimes I'll be in the same location and I'll lose the signal while other times I'll receive a strong signal. Anyone have any tips on how to maximize the pager receiving capabilities.
kc5igh
Velarde, New Mexico
Hey all,
If you're having these problems with reception in the 700 - 800 MHz range, you might consider buying a BNC antenna adapter from Jon Wienke and trying out some other antennas.
Keep in mind that the G5 uses an internal antenna for its VHF/UHF reception (depending on the model you bought) and its external antenna for 700 - 800 MHz reception. That means you only have the option to experiment with other antennas in the 700 - 800 MHz range.
Hope this helps!
-Johnnie (KC5IGH)
Giddyuptd
Here and there
With that said does the g5 actually offer a option for both 700 and vhf for outer antenna or only internal on vhf?
APX8000
Sarcastic Member
AES-256 secured
7/800, VHF or UHF ? The external antenna on a G5 is 7/800. Internal loop antenna is either VHF or UHF depending on model. So depending on your conventional paging frequency (which I'm assuming is V or U) my answer is your location in proximity to the transmitter.
Only internal on VHF. Otherwise look at the G2 or G3.
